Did they send the wrong plate? - Router Forums
post #1 of 4 (permalink) Old 12-12-2009, 12:07 PM Thread Starter
Default Did they send the wrong plate?
Hello,
Months ago when I started my router table project I bought a router plate off of Rockler. I then got caught up with other issues in life and its only recently that I got back to making my router table again. Today I unpacked the plate for the first time so I could size it up for when I cut my table. I then got distracted by trying to figure out how in the world my router is supposed to mount on to this thing. I have a Bosch 1617 and I plan to use the fixed base that came with my router so I can raise and lower the router from above the table.
Here is a picture of my router plate:
My current suspicion is that Rockler sent me the wrong router plate. If thats the case can anyone recommend a cheap router plate that will actually fit my router?
MinorHero is offline
post #2 of 4 (permalink) Old 12-13-2009, 01:37 AM
BigJimAK's Avatar
MinorHero,
You need to make 10 posts (you've got 4) before you can post pictures and your pictures would be very helpful here. If you will go greet a few folks in the Introductions forum, you can be there in a few minutes and it'll be easier to help.
BigJimAK is offline
post #3 of 4 (permalink) Old 12-13-2009, 09:33 AM
First Name: Henry
With the subbase removed from the 1617 fixed base, you will find three mounting holes. The fasteners come with the router. I used a stiff piece of clear plastic to mark the three holes plus the one for the adjustment.
ccmnova is offline
post #4 of 4 (permalink) Old 12-13-2009, 09:36 AM
First Name: Duane
Originally Posted by MinorHero View Post
Hello,
Hello,
Do the holes line up at all or are you having trouble just in general ?
Duane867 is offline
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Making a template, where did I go wrong? Thom2 Guide Bushings and Templates 10 08-09-2007 07:54 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
