Extension Collet? - Router Forums
post #1 of 30 (permalink) Old 12-15-2009, 12:27 PM Thread Starter
Default Extension Collet?
I am in the market for a collet extension to be able to change out bits while the router is mounted under the table. What options / features should I be looking for?
Thanks in advance!
Thomas Schneider is offline
post #2 of 30 (permalink) Old 12-15-2009, 03:42 PM
Mike Wingate's Avatar
First Name: mike
Accurate, easy to change bits. A good price and a few positive reccomendations. Try the deal at MLCS.
Mike Wingate is offline
post #3 of 30 (permalink) Old 12-22-2009, 09:59 PM
First Name: Daniel
I have one, but have yet to use it. It seems hefty. The router better have good bearings.
Dan
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #4 of 30 (permalink) Old 12-22-2009, 10:44 PM
Hi
Extension Collet no big deal at all ...
Many 1/4" and some 1/2" bits are just to short, the Extension will take care of that error, many and I have pull the bit out of the collet to the max and it's not safe and I know that and the extension makes it a safe way to use the router bits plus it will let you change the bits out from the top side of the router table.
Take a hard look at the BIG panel bits, now that's a real test for the router and it must have good bearing to swing that mass of steel at 40 mph...on the end of a 1/2" shank of steel not to say anything about when it hits the stock at 40 mph..and gets that shock...
I'm just a user of the Extension and to me it's like getting slice bread after not having any...
Dan
post #5 of 30 (permalink) Old 12-22-2009, 11:10 PM
TWheels's Avatar
Tom,
Look at the collet extenders sold by MLCS. If you are in the U.S. you can get them very quickly. The seem to be solidly built and add minimal chances for wobble or other forms of unsteadiness. The best and safest situation of course is for the router bit to be attached directly in the collet. Have you considered alternatives such as Router Raizer, bent wrenches that allow you to work above the table while the collet is below the table.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #6 of 30 (permalink) Old 12-23-2009, 08:03 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Whilst I have a CMT extension, it's used on the rare occasions when that extra depth of cut is necessary but I would never consider using it full time, as Tom has mentioned, it's safest to have the cutter directly into the collet and use other methods to change cutters from above. You haven't stated what router you have, whether two spanners are required or one with a spindle lock in which case one hand would still need to be under the table to hold it engaged.
Harry
harrysin is offline
post #7 of 30 (permalink) Old 12-23-2009, 08:12 AM
First Name: mike
What model do you use Bobj3?
post #8 of 30 (permalink) Old 12-23-2009, 11:07 AM
Hi
Harry you crack me up " spanners " hahahahaha LOL LOL LOL
http://www.koalanet.com.au/australian-slang.html
Mike,,I use the MLCS brand,,
post #9 of 30 (permalink) Old 12-23-2009, 11:19 AM
dustmaker's Avatar
First Name: Frank
If you are not looking for much extra height or just want the convenience of table top bit switching, you might look at the Eliminator RC. I used one of these for a while with the DeWalt 625 and it works great.
Eliminator RC Chuck - NewWoodworker.com LLC
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #10 of 30 (permalink) Old 12-23-2009, 11:38 AM
Hi Frank
I tried one but didn't like the little nick the set screw puts in shank of the bits ... then if I would use the bit in some other router without the Eliminator it would hang up just a little bit and I was not to sure if the bit was in right and tight ,,,the MLCS works just like the chuck on the router
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Collet extension diameter?? Pirate General Routing 3 08-10-2009 01:09 PM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
Mounting a Ryobi R175 Plunge Router bobtheengineer Table-mounted Routing 6 01-14-2009 01:34 AM
