NVR Switch - Router Forums
post #1 of 6 (permalink) Old 12-20-2009, 02:10 PM Thread Starter
First Name: Steve
Default NVR Switch
Hi Guys and Happy Christmas from the UK!!
I need an NVR switch for my table mounted DW625EL. They don't seem to be available in the UK. Can anybody recommend a supplier from the US?
Steve
Barreller is offline
post #2 of 6 (permalink) Old 12-20-2009, 03:14 PM
Hi Steve
Try the links below
Power Tool NVR Switch : Buy Power Tool NVR Switch at Axminster Power Tool Centre
Wealden Tool Company Limited NVR switch
Steve
post #3 of 6 (permalink) Old 12-21-2009, 02:20 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Steve
Hi Steve
Bob's links are good and Axminster is reasonably handy. OK, having spent time in South Devon I know North Devon and North Somerset are a fair trek away.
US ones would be the wrong voltage anyway.
I would have thought that your local electrical wholesaler could order up NVR switches if they haven't got them in stock. All the schools workshops I've seen use them and so do commercial ones. RS Components surely list them.
Welcome to rswww.com
Cheers
Peter
istracpsboss is offline
post #4 of 6 (permalink) Old 12-21-2009, 02:42 AM Thread Starter
First Name: Steve
Hi Guys and thanks for the replies. What I didn't say, as this is a US forum, is that my router is 110 volt. Axminster (or "Toys for Boys" as it is known around here) only do a 240 volt version.
Steve
post #5 of 6 (permalink) Old 12-21-2009, 03:36 AM
Mike Wingate's Avatar
First Name: mike
I got mine from Charnwood W025 Nvr Switch, For Use With Any Router Table CNWW025 from Wokingham Tools
There should be no problem running a 110v tool from it as it is lower powered and still should take the amps.
Mike Wingate is offline
post #6 of 6 (permalink) Old 12-21-2009, 11:05 AM Thread Starter
First Name: Steve
Thanks Mike.
I emailed Charnwood and they replied that their switch is only for 240volts. Incidentally the DW625EL is 1850 watts so at 110 volts the current is more than double that at 240 volt for the same power (I'm not sure that you can do a simple Ohms law on this but it has to be close!) It seems that the only one available generally in the UK is the Trend one at 80 which seems a bit steep for a switch!! I'm still looking.
Steve
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Bosch Router Switch Problem bill kay General Routing 41 11-19-2010 08:29 AM
***Urgent*** Switch problem uzzaljss Lobby 1 07-16-2009 11:27 AM
Router ON/OFF Switch kolias Portable Routing 42 06-11-2009 08:40 PM
Router switch at last! Birch Table-mounted Routing 1 03-07-2009 09:28 PM
