Sigh... all that work for nothing... - Router Forums
post #1 of 35 (permalink) Old 12-20-2009, 10:53 PM Thread Starter
First Name: Tim
Default Sigh... all that work for nothing...
So I between going out and buying the wood and working on the jig I spent most of yesterday building a box joint jig. It's a 1/4" jig and I did the set up to test it with hardboard.
I finally got it adjusted where it made a real nice set of joints. The hardboard would chip out badly or the surface layer would de-laminate. I figured that it was just the board.
So I ripped the 1/4" poplar down to the size I needed for the candle stands I was planning on building. I grabbed a couple scraps so I could make sure that the setup that I came up with using the hardboard would work. It did not... The poplar was apparently more brittle than the hard board. Every time I tried to cut a pin it would break lose and go flying across the room. (or at least 3 or 4 feet.)
I gave up and moved on to the next project as I wanted the candle holders as a Christmas present.
Any ideas what I need to do to make it work with this wood?
Tim
"But before we use any power tools lets talk about shop safety. Be sure to read, understand, and follow all the safety rules that come with your power tools. Knowing how to use your power tools properly will greatly reduce the risk of personal injury. And remember this... There is no more important safety rule than to wear these... safety glasses." -- Norm
tdsapp is offline
post #2 of 35 (permalink) Old 12-20-2009, 10:58 PM
First Name: Duane
Hi Tim,
The Rockler box joint jig is well worth the money IMHO.
It could use some improvements but it works well and accurately.
Would be $80 well spent if you are into box making.
It sounds like your bit is dull to me though honestly.
Try cleaning it with simple green or orange clean. If it still does it after cleaning replace the bit.
You can also use a backer board and a sacrificial board up front of the work piece while cutting your joints to prevent tear out and "fly away's ".
Duane867 is offline
post #3 of 35 (permalink) Old 12-20-2009, 11:24 PM
Hi Tim
You can try this, don't back out of the pass, if the jig is just off a little bit the router bit will hang up on it if you back out and snap the part free...
post #4 of 35 (permalink) Old 12-21-2009, 07:21 AM
do you have any pictures of your set up? might help us figure out whats wrong
Mike Gager is offline
post #5 of 35 (permalink) Old 12-21-2009, 08:50 AM
rwyoung's Avatar
First Name: Rob
Hi Tim
+1 on don't run backwards across the jig. Lift off the workpiece and backer board after the pass.
Also, if you can get one, a spiral bit seems to do a better job with these jigs. That said, I've used a straight cutter but only on larger fingers. To minimize chipping on the piece I wrapped the cutting area in blue tape. Seemed to help.
rwyoung is offline
post #6 of 35 (permalink) Old 12-21-2009, 09:30 AM
First Name: Brad
There is a cheap and easy jig that Norm makes for box joints. It is done on the table saw. Basically a vertical board, mounted to a miter gauge, with two rectangular dowels and a dado in the vertical board.
Very easy to make and works great and does not cost a thing.
I suggest a board in front and in back of your work to reduce the change of tear out while cutting.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #7 of 35 (permalink) Old 12-21-2009, 03:51 PM
Ghidrah's Avatar
First Name: Ronald
I make all my box joints on the TS and never had that problem.
Ghidrah is offline
post #8 of 35 (permalink) Old 12-21-2009, 03:57 PM
Hi Ron
I Can't wait till you try the OP box joints jigs out, it will blow your mind how easy and fast you can make them.. and they always come out just right every time...unlike the table saw way, been there done that.. or should I say the dado saw king way (Norm A. way)
post #9 of 35 (permalink) Old 12-21-2009, 04:05 PM
TwoSkies57's Avatar
I crank out box joints on the TS without a hitch.. nice clean joints...
no need for an OP
TwoSkies57 is offline
post #10 of 35 (permalink) Old 12-21-2009, 05:01 PM
levon's Avatar
First Name: levon
+1 on the oak park box joint jigs! they work time after time and are so simple to use.
i might add that they are priced very reasonably.
levon
levon is offline
Quick fix for router work. jigman Portable Routing 12 02-22-2010 04:55 PM
Wives brother-in-law's work xplorx4 Lobby 4 06-29-2009 09:34 AM
building a work bench reikimaster Tools and Woodworking 12 10-13-2006 11:12 AM
