need help - Router Forums
post #1 of 8 (permalink) Old 12-23-2009, 11:19 PM Thread Starter
Default need help
what router table can i buy that will fit a hitachi 3 1/4 hp router?
torence20 is offline
post #2 of 8 (permalink) Old 12-24-2009, 12:01 AM
Oak Park Enterprises Ltd.: Catalogue
Oak Park Enterprises Ltd. - Router Table, Router, Router Bits, Router Jigs, Router Accessories: base plate guide
post #3 of 8 (permalink) Old 12-24-2009, 10:11 AM
curiousgeorge's Avatar
First Name: George
Any one you want to buy. You may have to re-drill the mounting plate if you can't find one that the hole pattern matches your router, but that is normal and no big deal.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 8 (permalink) Old 12-24-2009, 01:29 PM
dawziecat's Avatar
First Name: Terry
I second George. Just drilled a phenolic plate to accommodate my router yesterday. No big deal. An Al plate might be a bigger deal . . . but only slightly I think.
The "problem" I had was in getting M4 screws to hang the router with. Hardware stores here had M4 bolts, but with heads that were too thick to countersink. Providentially, my router came with a set of "extra long" M4 screws in addition to the little stubbies needed to mount the standard plate. It was as if the manufacturer anticipated this requirement although the manual does not make any mention of them. They were too long, of course. I cut 'em to the right length with a hacksaw. Hardly recommended as I had no metric dies to clean the threads up with afterward. But they did the job OK.
Terry Danks
Rural Nova Scotia(or Florida)
Nature and Wildlife Photography
http://danks.netfirms.com/home.htm
dawziecat is offline
post #5 of 8 (permalink) Old 12-24-2009, 01:43 PM
Hamlin's Avatar
First Name: Ken
First off, welcome to the router forums.
Now, to answer your question. Bj and George are both correct. However, there are some questions you have to ask yourself. What are you looking for in a table? Do you want one that has all the "bells and whistles" or one that follows the K.I.S.S. rule. The Oak Park table follows the latter and I've always recommended. MLCS, Rockler, Woodcraft and many others sell many different router table styles. Most of these have the "bells and whistles".
It boils down to, what are YOU looking for in a table. Technically, as George pointed out, it's the plate that the router mounts too, not the table.
Ken
"A VETERAN"
Hamlin is offline
post #6 of 8 (permalink) Old 12-24-2009, 07:42 PM
BigJimAK's Avatar
+1 on BJ's recommendation, unless you are looking to spend megabucks.
BigJimAK is offline
post #7 of 8 (permalink) Old 12-25-2009, 01:02 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Torence, and welcome to the RouterForums.
Dave
the "Doctor"
Dr.Zook is offline
post #8 of 8 (permalink) Old 01-01-2010, 09:29 PM Thread Starter
well i ended up going to menards an buying a table made by wolf, its nothing really fancy i had to redrill the plate to make an adapter, and i had to widen the hole in the center a bit, i made a cabinet over christmas, made two raised panel doors with my new table, turned out pretty good, thanks for the help guys,
