Rebate lip for plate and cutting radius - Router Forums
post #1 of 11 (permalink) Old 12-25-2009, 02:09 PM Thread Starter
First Name: Greg
Default Rebate lip for plate and cutting radius
Hi all and a very merry christmas,
I have just recieved my Woodpeckers Phenolic router plate and intend to cut it in today .
How much of a rebate lip should I leave for the plate to sit on.
I was thinking of about 1/2 inch or more.
What is the best way to cut the corner radius .They are about 1 1/2 inch (40 mm)
The instructions say to use a 40mm forstner bit,which I dont have and everything is closed at the moment.
Thanks in advance
Regards
Greg
L
gregmw is offline
post #2 of 11 (permalink) Old 12-25-2009, 02:26 PM
Hamlin's Avatar
First Name: Ken
I wouldn't go any deeper than the thickness of your plate. In fact, it's best if the plate is level or slightly above the table surface.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 11 (permalink) Old 12-25-2009, 02:39 PM Thread Starter
First Name: Greg
Sorry,I wasn't real clear with the question.
The depth is OK (3/8) but the actual width of the lip where the plate sits on.
gregmw is offline
post #4 of 11 (permalink) Old 12-25-2009, 04:49 PM
BigJimAK's Avatar
Greg,
I've heard a number of folks here recommending 3/8 of an inch but I used 1/2" for my Incra/Jessem Mast-R-Lift and heavy PC7518 router, the lift is designed to lock in with a 3/8" to 1/2" lip and I would go with it again. In retrospect it isn't all that important as long as the plate is rigid. With a rigid plate, the force is directly downwards, in a shearing action, so the thickness of the table beneath the lip is where the strength lies.
BigJimAK is offline
post #5 of 11 (permalink) Old 12-25-2009, 05:33 PM
First Name: George
I'm thinking the more meat ya got to support the router and plate the better off you are.
You just don't want the opening to interfere with the routers operation...
Anyhow that's what I think, it works for me..
Best Regards
George Cole
"Regulae Stultis Sunt"
George II is offline
post #6 of 11 (permalink) Old 12-25-2009, 05:52 PM
Hamlin's Avatar
First Name: Ken
I'd have to agree with the 3/8" to 1/2" width for the "lip". More support, the better.
As for the corners, I'll have to leave that for someone more knowledgeable than I for this operation. Bobj will most likely chime in soon, he's the expert.
Ken
"A VETERAN"
Hamlin is offline
post #7 of 11 (permalink) Old 12-25-2009, 06:48 PM
HI
You don't need to use a forstner bit you can use a 40 mm guide or 1 1/2 guide ,just chuck a 1/4" /6mm bit and let the guide do the work for you..it can be a square template in the corners but the guide will follow the edge of the board..you may need to use a bigger bit but use the smaller bit to start out with.. and you will get a nice radius in the corner.
post #8 of 11 (permalink) Old 12-26-2009, 12:57 AM
edhills's Avatar
First Name: ed
Thanks BobJ your links were real eye openers and they helped me understand more of what the router can do... thanks
edhills is offline
post #9 of 11 (permalink) Old 12-26-2009, 06:37 AM
Twill57's Avatar
Ed:
If you did not get your plate installed, here is link to the Woodpecker site template page. Woodpeckers recommends a 5/8" diameter bit. Router Table Mounting Plate - Template
Twill57 is offline
post #10 of 11 (permalink) Old 12-26-2009, 01:39 PM Thread Starter
First Name: Greg
Thanks for all the replies.
I think I will make the lip 1/2 + as I agree that the more support the better.
Its interesting reading some of the posts regarding template guides.I have never used them before,but after reading through here I think I might get some because I can see how it would make custting this out easier!
Regards
Greg
gregmw is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Climbing, climb cutting TWheels Tools and Woodworking 9 08-27-2009 12:10 PM
Rebate cutting Snapper Table-mounted Routing 2 09-16-2008 10:20 AM
Cutting dados on a router table paulcomi Table-mounted Routing 6 08-05-2006 10:52 PM
