Saw dust plugging cooling slots - Router Forums
post #1 of 34 (permalink) Old 12-25-2009, 10:41 PM Thread Starter
Astrowood's Avatar
First Name: Roy
Default Saw dust plugging cooling slots
I have only just started to use my new Freud in the router table. Today I was doing a lot of corners with a 1\4 round over bit. It made a lot of fine shavings that plugged the cooling slots in the router - is this normal ? And is there something that will prevent this ?
Astrowood is offline
post #2 of 34 (permalink) Old 12-25-2009, 10:55 PM
Do you have it in cabinet with doors on it ?
post #3 of 34 (permalink) Old 12-26-2009, 02:41 AM
First Name: Duane
Also, are you vacuuming as you do the work or after your finished ?
Duane867 is offline
post #4 of 34 (permalink) Old 12-26-2009, 08:52 AM Thread Starter
Astrowood's Avatar
First Name: Roy
No, currently the router is in a table with no cabinet. I have vacuuming at the fence, but as you can see, not below.
post #5 of 34 (permalink) Old 12-26-2009, 08:57 AM
First Name: George
Ok "no name" I have the same router as yours mounted under the table..I use the dust chute attached with the router as well as the router fence. It is normal for the vents to clog up without it...The router motor could overheat and quit..
Good Luck..
George Cole
"Regulae Stultis Sunt"
George II is offline
post #6 of 34 (permalink) Old 12-26-2009, 02:13 PM Thread Starter
Astrowood's Avatar
First Name: Roy
Wow, pretty obvious answer - never said that I was the sharpest tool in the box !
I will give this a try this afternoon. Thanks
post #7 of 34 (permalink) Old 12-26-2009, 02:18 PM
I do the same as George but the beast needs TLC from time to time , I just turn on the vac.and suck out the chips and blow out router at the same time..
post #8 of 34 (permalink) Old 12-27-2009, 01:11 AM
First Name: Duane
What I was leading to.
Duane867 is offline
post #9 of 34 (permalink) Old 12-27-2009, 08:46 AM
Hamlin's Avatar
First Name: Ken
I will either vacuum or use compressed air to blow mine out at the end of each day of use or week. Just depends on how much I use them and how dust I've created at the time of use.
Ken
"A VETERAN"
Hamlin is offline
post #10 of 34 (permalink) Old 12-27-2009, 10:03 AM
dawziecat's Avatar
First Name: Terry
Good Luck..
George Cole
You mean something like is pictured at the following link?(I seem unable to attach the image). My router came with this attached. http://danks.netfirms.com/Tube.jpg
I am supposed to actually use this thing? That means I need a Y adapter to get both fence and this tube connected to the shop vac. I haven't seen such adapters readily available at the hardware stores. This would also make it a mini nightmare to remove the router from the table by lifting the plate to change bits.
You fellows are actually using something to vac the dust from the collet area while the router is in use in a table?
Terry Danks
Rural Nova Scotia(or Florida)
Nature and Wildlife Photography
http://danks.netfirms.com/home.htm
dawziecat is offline
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 06:58 AM
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
Rockler Dust Collector Terry Pepper Tools and Woodworking 4 12-21-2008 08:48 PM
Practacle Dust control for "part timers" bob oswin Tools and Woodworking 34 07-31-2008 07:26 PM
