Plastic Laminate - Router Forums
post #1 of 3 (permalink) Old 12-27-2009, 10:43 AM Thread Starter
Default Plastic Laminate
Hello all!! I am in the process of designing a new router table. I want to use plastic laminate as the top (and bottom) material. I know lowes has sheets of laminate that are about $40-60 a sheet. Are there any more affordable sources of plastic laminate or am I stuck paying the lowes price?
Thanks in advance!
Stevenlgts is offline
post #2 of 3 (permalink) Old 12-27-2009, 11:27 AM
First Name: Duane
Hello Steve,
You are stuck paying those prices unless you can find a local supplier of phenolic laminated birch. Rockler used to carry it, and its been suggested that it is used to make concrete forms and could possibly be found in scrap pieces or full sheets from construction / concrete companies.
Duane867 is offline
post #3 of 3 (permalink) Old 12-27-2009, 11:29 AM
Gene Howe's Avatar
First Name: Gene
Steve,
Contact a counter top fabricator, or often a cabinet maker. They usually have off cuts that they may give you free. If they don't have any the size you need, they may be able to steer you to a less expensive alternative than Lowes.
If you lived close to me, I'd have some for you.
edit: Just saw Duane's post. That's a good idea and you won't have to mess with doing the lamination yourself.
Gene Howe is online now
Trimming laminate...Some info please Bonehead V.2 General Routing 10 04-09-2014 01:48 PM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
Plastic laminate S Bolton Table-mounted Routing 12 03-16-2008 06:40 PM
glue for plastic laminate S Bolton Table-mounted Routing 8 09-29-2007 12:05 PM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 12:56 PM
