Trouble with Tear-out...Help! - Router Forums
post #1 of 11 (permalink) Old 12-28-2009, 09:42 PM Thread Starter
First Name: Rex
Default Trouble with Tear-out...Help!
I'm new to table mounted routing and am currently having trouble by getting a great deal of tear-out while trying to remove 1/8" of pine material along half of the length of a 3/8" thick piece of stock. I am using a new bit and have just pushed the stock down the fence to a clamped stop. I've tried to go slower, tried slower router speeds...
I am trying to leave a rounded inside shoulder on each side of this board.
I know this is very elementary as I have watched what you all can do.
Thanks for any help.
Rex
rpoulson is offline
post #2 of 11 (permalink) Old 12-28-2009, 09:49 PM
First Name: Duane
Hey Rex,
Welcome to the forum.
Are you routing end grain ?
Duane867 is offline
post #3 of 11 (permalink) Old 12-28-2009, 10:18 PM
RStaron's Avatar
First Name: Ron
Try doing it in two passes. Is it construction grade or select? Select has a tighter grain.
A person can never have too many tools!
RStaron is offline
post #4 of 11 (permalink) Old 12-28-2009, 10:50 PM Thread Starter
First Name: Rex
No end grain, Duane, this is just running down the stock.
Thanks,
Rex
rpoulson is offline
post #5 of 11 (permalink) Old 12-28-2009, 10:56 PM Thread Starter
First Name: Rex
Thanks, Ron, I will try that. This is construction grade pine and I was doing a lot of these but I will run them twice with this radius and if doesn't work maybe use a shorter radius.
Rex
rpoulson is offline
post #6 of 11 (permalink) Old 12-31-2009, 09:16 AM
RLFX's Avatar
First Name: Randy
try a different RMP ..
RLFX is offline
post #7 of 11 (permalink) Old 12-31-2009, 10:04 AM
gallianp's Avatar
First Name: Paul
What is a "RMP"? typo? RPM ?
From S.W. Missouri
Near but not too near Springfield
gallianp is offline
post #8 of 11 (permalink) Old 12-31-2009, 04:55 PM
First Name: Ian
Hi Rex - I think you may be presenting the wood in the wrong direction. If the router is under the table and the cutter sticking up, you should be pushing the wood, against the fence, from the right and with a new cutter it will cut cleanly. I hope I am not telling you how to suck eggs. Regards Ian UK
Ian1930elm is offline
post #9 of 11 (permalink) Old 12-31-2009, 08:30 PM Thread Starter
First Name: Rex
I have presenting in the correct direction. I have been using two passes to reduce the tear out and that helped a little. I just got through feeding some more pieces through and this time I added a sub-fence to the face of the table fence and used a much smaller opening, just a little larger than the bit, and this worked great!
So why the big difference??? I'm going to run some more tomorrow with different wood but for now the results seem quite different and I don't understand why.
rpoulson is offline
post #10 of 11 (permalink) Old 12-31-2009, 10:21 PM
RStaron's Avatar
First Name: Ron
The difference is more support where the cutter is coming out of the piece you are
routing = less tearout. Sometimes painters tape ( masking tape ) helps also.
RStaron is offline
Baltic Birch Tear Out Ross Wigle New Member Introductions 7 01-06-2010 09:16 AM
jig for tear drop hole gabers Jigs and Fixtures 5 01-29-2009 01:56 PM
Katie Jig and tear out S Bolton Jigs and Fixtures 8 10-04-2008 03:24 PM
HELP!! Tear out... wil141 Table-mounted Routing 4 05-09-2007 04:57 PM
Dovetail trouble Drick Table-mounted Routing 2 06-02-2005 03:38 PM
