T Track fitting - Router Forums
post #1 of 8 (permalink) Old 12-30-2009, 03:44 AM Thread Starter
First Name: Greg
Default T Track fitting
I have cut a slot for the t track in the top but its not a real tight fit and has a very slight gap (about 1/2mm) down the length of the track.
Should I epoxy the track in and try to fill the gap or just screw it in and dont worry about it.
Greg
gregmw is offline
post #2 of 8 (permalink) Old 12-30-2009, 07:22 AM
First Name: Trent
Greg
I would make sure it is parallel to the edge (providing that is critical to it's use) and screw it in. You might want to remove it at a later time and epoxying it would make that difficult.
If the gap becomes a problem you could try filling it in or replacing the track with t-track that is wider or a combination t-track/miter slot.
the_nite_owl is offline
post #3 of 8 (permalink) Old 12-30-2009, 08:35 AM
BigJimAK's Avatar
+1 on not filling it in. If it accumulated wood chips (or was bothersome), I'd put something removable in there. Perhaps a thin strip of rubber or plastic?
BigJimAK is offline
post #4 of 8 (permalink) Old 12-30-2009, 09:10 AM
Mike Wingate's Avatar
First Name: mike
use a paper or card shim.
I am not keen on tracks as they fill up with dust.
Mike Wingate is offline
post #5 of 8 (permalink) Old 12-30-2009, 02:05 PM
AxlMyk's Avatar
I wouldn't worry about it.
AxlMyk is offline
post #6 of 8 (permalink) Old 12-31-2009, 08:35 AM
RLFX's Avatar
First Name: Randy
Screw her Down !
RLFX is offline
post #7 of 8 (permalink) Old 12-31-2009, 08:39 AM
TRN_Diesel's Avatar
You could try to ripp a piece to insert into the track and glue it place. Once it has dried you can try re-cutting the track. I am onot sure if you have the top laminated or not but if you haven't got the top laminated you could refill the track with a piece of material and then laminate and then redo the track.
How did you cut the dado for the track? Did you use a router bit or a stacked dado on the tablesaw?
TRN_Diesel is offline
post #8 of 8 (permalink) Old 12-31-2009, 01:51 PM Thread Starter
First Name: Greg
Yes the top is laminated.I used a 1/2 inch router bit to cut the slot.
I think what happened is that I was using a straight edge and it has moved slightly at one end.
I might end up leaving it the way it is at the moment ,but I was thinking of gluing a piece in a cutting it again if it became a problem,
Thanks for the replies,
Regards
Greg
gregmw is offline
UHMW strips not fitting into miter slot - how to remedy? xvimbi Jigs and Fixtures 5 11-01-2009 09:32 PM
T track sourcing westend Tools and Woodworking 12 06-22-2009 10:56 AM
Miter track Bdog Table-mounted Routing 7 03-07-2009 10:49 AM
T track modification locoboy General Routing 5 10-15-2008 03:38 PM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
