No Gap Track fitting method. - Router Forums
post #1 of 1 (permalink) Old 01-03-2010, 12:12 PM Thread Starter
Mike Wingate's Avatar
First Name: mike
Default No Gap Track fitting method.
Just watched Norm's episode of the router table construction. I don't have a dado blade to cut the slot (not that I want one) for the T/U track for the mitre attachment/sled device. If you are laminating your table, which is a good method to build up thickness, and allow easy cutting and fitting of the router plate. Cut the top piece where you want the slot to go. Fix/fasten glue the larger piece. Place U/T track in place,screw down with 2 smaller length screws to hold temporarily, butt smaller piece to it and fix. Cut off overhang from where the track went and a no gap slot.
Mike Wingate is offline
Where can I find this Slick method for cutting router plate opening into table Peter Sanders Table-mounted Routing 25 10-17-2015 01:57 PM
T Track fitting gregmw Table-mounted Routing 7 12-31-2009 01:51 PM
UHMW strips not fitting into miter slot - how to remedy? xvimbi Jigs and Fixtures 5 11-01-2009 09:32 PM
T track sourcing westend Tools and Woodworking 12 06-22-2009 10:56 AM
T track modification locoboy General Routing 5 10-15-2008 03:38 PM
