router bit wiggle - Router Forums
post #1 of 3 (permalink) Old 01-03-2010, 02:23 PM Thread Starter
Default router bit wiggle
Hello all I recently bought the 2 1/4 triton router and one of the table kits from rockler everything works good accept that you can wiggle the bit back and forth slightly at first I thought it was a defective collet so I got a new on from triton wich didn't fix the problem so then I got all new stainles mounting screws as the ones that were supplied were not very long.The wiggle decreased alot once you lock the plunge adjustment but it's still there almost as if the armateur in the motor as a little side to side movement so my question is do you have any idesas what it could be,is this normal should I try and get a replacement.
Angus89 is offline
post #2 of 3 (permalink) Old 01-03-2010, 02:37 PM
First Name: del
[QUOTE=del schisler;155053]I don't belive i would go with that The beiring's should be no wobble Call them and ask for a exchange my 3 cents worth inflaction
del schisler
port st. lucie, florida
del schisler is offline
post #3 of 3 (permalink) Old 01-03-2010, 04:22 PM
First Name: Duane
Get a replacement. Sounds like there was a defect in manufacturing involving the arbor and or bearings.
Duane867 is offline
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
