First Raised Panel . . . they're were problems . . . - Router Forums
post #1 of 2 (permalink) Old 01-10-2010, 07:08 PM Thread Starter
dawziecat's Avatar
First Name: Terry
Default First Raised Panel . . . they're were problems . . .
Well it was time to give it a try.
Using an ogee vertical raising bit.
Problem 1:
How do I set the fence?
Trial and error to get the correct edge thickness was very tedious and error prone. Is there a better way? I tried several tests and never got it quite right.
Problem 2:
TERRIBLE tear out on the face of the raised panel surface on the cross grain cut!. Absolutely terrible
I attributed this to the need to have a zero clearance fence for the cutter.
Well how do I do that SAFELY? I did it by sliding the sub fence on the infeed side into the cutter. You guys immediately know what happened. The cutter grabbed the subfence . . . WHAM! I had a zero clearance fit all right . . . but sure not safely! My first, totally inadvertent climb cut.
Fortunately the outfeed fence was firmly tightened and stopped the infeed section from becoming a projectile.
I trimmed the panel and tried the cross grain cut again, this time with the zero clearance fence. Much better. No tear out other than is to be expected at the edge of the cross grain cut. That was minimal, easily cleaned up by the cut with the grain.
Problem 3:
$%^#@*& biscuits showed!
I think I can figure that one out by myself.
The first panel was a write-off. The second looks pretty good . . . but it is too loose in the rail and stile groove. I don't have the panel edge at the correct thickness yet.
PS: Disregard "they're" in heading. Should be "there." Can't edit subject apparently.
Terry Danks
Rural Nova Scotia(or Florida)
Nature and Wildlife Photography
http://danks.netfirms.com/home.htm
dawziecat is offline
post #2 of 2 (permalink) Old 01-10-2010, 08:06 PM
Hi Terry
You may want to check out the video below.it's best to use the right setup for the bits BUT you can make your own jig like below,you need to use a stop block on the back side of the fence, make one light cut and then move the fence back to the stop block and make the other cuts... run the bit at 12,000 rpm's.
MLCS Horizontal Router Table
http://www.routerforums.com/project-...th-worlds.html
Problem 1:
Problem 2:
Problem 3:
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
Raised Panel Projects ccmnova Table-mounted Routing 21 12-12-2009 11:42 AM
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 08:56 PM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
