Anyone using Route-R-Joint template jig? - Router Forums
post #1 of 13 (permalink) Old 01-13-2010, 01:37 PM Thread Starter
First Name: Trent
Default Anyone using Route-R-Joint template jig?
I picked up the Route-R-Joint system at a woodworking show over the weekend and am having a devil of a time with it.
My joints come out looking great and seem to line up well with each other but are too tight to put together without cracking the wood even using the smallest diameter guide bushing.
Anyone else use this successfully?
the_nite_owl is offline
post #2 of 13 (permalink) Old 01-13-2010, 01:54 PM
xplorx4's Avatar
First Name: Jerry
Greetings Trent and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 13 (permalink) Old 01-13-2010, 02:03 PM
Hi Trent
They are very tricky to cut,,you should have a air blow gun by to blow out the sockets, just a little saw dust in the pocket will stop the guide from doing it's job, one little chip will give you a error at glue up time and it only takes one socket to be off that little bit..
Be sure to use the right guide,,you will need to mike the ones you got with the jig...and RTM to know what one needs to be in place..
One Standard .308" OD Bushing
One Tighter Fit .311" OD Bushing
One Dovetail 7/16" OD Bushing
post #4 of 13 (permalink) Old 01-13-2010, 02:05 PM
First Name: George
I have one, Trent and it has been awhile since I used it I would have to go over the instructions and watch the DVD, with that said, I would call Woodline as there customer support if fantastic. I will go to my "Man Cave" and have a look at my instructions and get back to you..By the way, what joint are you attempting?
Regards,
George Cole
"Regulae Stultis Sunt"
George II is offline
post #5 of 13 (permalink) Old 01-13-2010, 03:23 PM
Mike Wingate's Avatar
First Name: mike
Have you accurately centred the guide bush?
Mike Wingate is offline
post #6 of 13 (permalink) Old 01-13-2010, 03:34 PM
see video
Fast Joint Precision Joinery System
post #7 of 13 (permalink) Old 01-13-2010, 03:35 PM Thread Starter
First Name: Trent
I have been using the .308 guide bushing as it is recommended when the joints are tight but no luck.
I make multiple passes cutting to clear out the dust and chips. I keep going till it's all clean and is not taking off wood any longer.
My guide bushing is centered, it fits very snugly into the plate and does not move around.
The one issue I DO have is that my PC router in the table does not adjust freely. Every time I raise the bit the router is tipping in the base and going off center and I have to fiddle around with it to get it centered again. Cannot figure out why it is doing that but it is new and I am about ready to bring it back.
In any event, I made sure the bit was straight up through the center of the guide, the guide did not move and I used the smallest guide. But these joints come out tight.
I need to practice more but I do not have suitable scrap. All I have in the area is Home Depot and all their wood is 1". I have a jointer/planer combo on the way but not sure how long it will be before it arrives.
post #8 of 13 (permalink) Old 05-03-2010, 05:27 PM
I'm also having a problem w my new Route-R- Joint sys.... first off my bit won't center in the guide bushing -- and joints seem cut smooth and clean I can't get the 2 pieces to seat even w a big fine adjustment tool..
Fredw is offline
post #9 of 13 (permalink) Old 05-03-2010, 05:45 PM Thread Starter
First Name: Trent
That's what is happening with me.
The main problem with centering the bit is with the guide bushing in the plate.
I have a Woodpecker plate and the PC style bushings I picked up at WoodCraft just do not seat down properly and I think it is tilted to one side a bit.
The guy that makes the Route-R-Joint system said I could send him my plate and he would machine it out for a perfect fit. I am going to have to take him up on it. Not sure if it is the Woodpecker plates or the WoodCraft bushings but both claim to be PC style. I have three of those size throat plates so I can send one to have it precision machined and still have two with original sizing.
Another problem I had with the system is that most of the templates were mis-cut. One side is deeper than the other so it goes at a slight angle. Have to exchange them for properly cut ones.
post #10 of 13 (permalink) Old 05-03-2010, 06:17 PM
BigJimAK's Avatar
I'm not familiar with that particular jig (I use the Incra and Katie jigs), but here's a couple of ideas to check...
As for tightness of the joint, as BobJ says "The deeper the bit the tighter the fit."
The other thing is to measure your bit carefully. If the bit is off-tolerance you can see that. In a precision joint like a dovetail, precise dimensions are important.
BigJimAK is offline
For Sale: Sears/Craftsman 2579 router dovetail joint template kit. $25, Craigslist Anchorage BigJimAK Woodworking Classifieds 0 01-09-2010 06:40 PM
Template Routing FlyFAmerica Portable Routing 11 12-21-2008 12:36 PM
Leight finger joint template S Bolton Jigs and Fixtures 0 07-29-2007 11:58 AM
One way of doing it ( box joint template ) Router is still my name Jigs and Fixtures 11 12-11-2006 02:21 PM
