box making - Router Forums
post #1 of 20 (permalink) Old 01-18-2010, 12:19 PM Thread Starter
First Name: david
Default box making
Hi how can i cut 45% angles on the router table with 1/4 inch material . any advice would be helpfull . Thanks .
papabob is offline
post #2 of 20 (permalink) Old 01-18-2010, 12:30 PM
Smile
Hi David, Welcome to the forum
I am assuming you want to bevel the ends at 45*. I would suggest a chamfer bit and push block. Could also be done pretty easily on a table saw, not sure what tools you have available.
Edit - Just went over and read your profile. I apologize for not doing that first. If your bandsaw table tilts that would also be a nice way of doing it. Lots of options here.
John Schaben
jschaben is offline
post #3 of 20 (permalink) Old 01-18-2010, 12:43 PM Thread Starter
First Name: david
thanks John i dont seem to have much joy on the band saw can never seem to keep it straight but will try the chamfer bit on the table.
papabob is offline
post #4 of 20 (permalink) Old 01-18-2010, 02:41 PM
First Name: Mike R
Hello papabob
I had asked the same question. Look under Tools and Woodworking tab for
45* on small pieces.
I havn't gotten the results I am looking for yet with the equipment I have but I still need to get my shooting board finished and I havn't tried Harry's disc sander method yet.
Good luck
awoodnut is offline
post #5 of 20 (permalink) Old 01-18-2010, 03:03 PM
Mike Wingate's Avatar
First Name: mike
Stick a block of wood with a good edge to your piece to be mitred (with double sided tape) make sure this piece is longer than the mitre and flush with the edge of where the mitre will be. put a mitre bit with a top bearing in the table. Set the router fence to the front of the bearing. Trim away so that the guide block runs across the fence.
Mike Wingate is offline
post #6 of 20 (permalink) Old 01-20-2010, 05:41 AM Thread Starter
First Name: david
Thank you Mike & Mike R . for your suggestions they are much appreciated and will give them all a try to see which works best for me .
papabob is offline
post #7 of 20 (permalink) Old 01-20-2010, 10:14 AM
Santé's Avatar
Country: Belgium
First Name: Daniel
You can make it by folding. whith a special bit on your router.
(y speek only french sory)
Santé
Santé is offline
post #8 of 20 (permalink) Old 01-20-2010, 11:16 AM
Question
Santé
Hmm, languages is a part of my education sorely neglected. I only speak the midwestern version of the american version of english, and not very well at that.
Anyway, and this is speaking mostly from ignorance, would it be possible to put V-grooves partially through 1/4" stock and soften it enough to fold into a box. Is that what Daniel may be alluding to?
John Schaben
jschaben is offline
post #9 of 20 (permalink) Old 01-20-2010, 11:31 AM
First Name: mike
That is what he was talking about. However, as wood is not treated as an engineering material, measured in thousandths of an inch. You will not get workable solution to the v-cut. Industry seem to be able to do it with speaker cabs and other wrap around products. But their stuff is often wrapped in veneer.Try and see. I have seen birch boxes made by the North American Indian First Tribes, that take a plank and fold it round, making a watertight container. Great stuff.
post #10 of 20 (permalink) Old 01-20-2010, 12:16 PM
Yeah, I've seen native american stuff done like that but it was done with birch bark, not planks.
John Schaben
jschaben is offline
New Member making Chairs Tracy White New Member Introductions 3 09-29-2009 01:08 AM
Making puzzles, looking for a jig idea kweinert Jigs and Fixtures 3 08-31-2009 07:59 AM
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 01:42 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
