Tenon making - Router Forums
post #1 of 23 (permalink) Old 01-19-2010, 01:21 AM Thread Starter
First Name: Phillip
Default Tenon making
I'm making flat panel doors for a 22 inch wide closet.
I'm using a Tongue and Groove bit set
I don't have any problems making the groove in the Stiles.
What I'm having trouble with is making the tongue (Tenon)
on the each end of the rail.
Rail
wide= 2-1/2"
long= 6"
thick= 3/4
tenon= 1/2"
Is there Jig I can make or buy that I could hold the work piece
and scrap wood and be able to move them across the bit smoothly.
Phillip
phillipd11 is offline
post #2 of 23 (permalink) Old 01-19-2010, 12:44 PM
First Name: Dirk
Hi Ho Philip: One simple solution is to just use a backer board about 6 or 8 inches square. You can put a handle on it if you want to. This holds your workpiece square to the fence and provides backup for chipout. You can use MDF, plywood, or the same material you are routing.
Good luck, Dirk
dirko is offline
post #3 of 23 (permalink) Old 01-19-2010, 02:23 PM
You can buy one from below
MLCS Safety Accessories
Rail
wide= 2-1/2"
long= 6"
thick= 3/4
tenon= 1/2"
Phillip
post #4 of 23 (permalink) Old 01-19-2010, 02:40 PM Thread Starter
First Name: Phillip
Thanks Dirko
One other question; Can I clamp the work piece and backer board together.
post #5 of 23 (permalink) Old 01-19-2010, 02:53 PM Thread Starter
First Name: Phillip
Thanks Bobj3
I looked at the MLCS coping jigs. It appears to me that the coping cut is not the same as a tongue and groove. If I usd a coping jig it appears to me that It would cut into the sled. I'm new so I still trying to figure out a lot of thiing.
post #6 of 23 (permalink) Old 01-19-2010, 03:09 PM
Hi
It will some times that's why they sale the replacement backer blocks as well ...BUT I will say you can make your own backer blocks out of MDF for each type of profile you have..or want to use the sled for, quick way to make your own setup blocks..
Thanks Bobj3
post #7 of 23 (permalink) Old 01-19-2010, 04:10 PM
First Name: Vincent
Default Make Your Own Rail Coping Jig
You can make your own jig for a lot less. The below site has a good design.
maniac424 is offline
post #8 of 23 (permalink) Old 01-19-2010, 07:35 PM
Here's just two more
post #9 of 23 (permalink) Old 01-20-2010, 04:31 PM
BigJimAK's Avatar
thick= 3/4
tenon= 1/2"
Phillip
Phillip,
I'm probably misunderstanding what you're saying here but is it 1/2" tenons for edge joining 3/4" stock? To me, that seems pretty thick since that only leaves 1/8" side wall for each side of the mortises (and that assumes the mortise is perfectly centered). Perhaps others will comment but I've always been told that a tenon that's ~1/2 of the thickness is the norm, to leave reasonably thick side walls.
BigJimAK is offline
post #10 of 23 (permalink) Old 01-20-2010, 09:06 PM
Hi Jim
That's common, it's like putting in two tenons 1/4" wide on/in a 3/4" wide board.
see video on the FMT
http://www.rockler.com/product.cfm?p...er=tenon%20jig
Originally Posted by BigJimAK View Post
Phillip,
Beadlock Pro loose tenon jig boballten New Member Introductions 5 01-21-2010 06:00 AM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
New Member making Chairs Tracy White New Member Introductions 3 09-29-2009 01:08 AM
Tenon & Mortis to work piece ratio Sawtooth General Routing 9 01-23-2009 10:29 AM
