MDF for a fence - Router Forums
post #1 of 10 (permalink) Old 01-22-2010, 02:27 PM Thread Starter
First Name: Greg
Default MDF for a fence
Hi,
I am still building my first table and I was going to use some MDF with plastic laminate over it for a fence.
I will be putting 2 tracks in the table to hold/adjust the fence.
My other thought was to try to get a piece of Aluminium angle and use that with the MDF screwed to it.
I need to have the fence split so I can use it to plane edges.
Any comments welcome ,
Regards
Greg
gregmw is offline
post #2 of 10 (permalink) Old 01-22-2010, 03:06 PM
Mike Wingate's Avatar
First Name: mike
Mdf is fine, but quality ply is better.
Mike Wingate is offline
post #3 of 10 (permalink) Old 01-22-2010, 03:21 PM
First Name: Richard
Hi MDF will work just fine. As far as plaining edges, all that is needed is a shim the thickness you want to take off when you plane, and some double sided tape.
Good luck with it, woodnut65
Woodnut65 is offline
post #4 of 10 (permalink) Old 01-23-2010, 01:18 AM Thread Starter
First Name: Greg
Thanks for the replies,looks like MDF is the go.
gregmw is offline
post #5 of 10 (permalink) Old 01-23-2010, 02:32 AM
xplorx4's Avatar
First Name: Jerry
I usad it in my fence, with an alumminam base, works well!!
Lamentations 3:22-23
xplorx4 is offline
post #6 of 10 (permalink) Old 01-23-2010, 07:40 AM
First Name: mike
Give the MDF a couple of coats of polish, that will toughen it up a bit and make for a slippy, friction free surface.
post #7 of 10 (permalink) Old 01-23-2010, 08:20 AM
RLFX's Avatar
First Name: Randy
That's what I used, works great !
Table Saw: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.I cut that board 3 times and it's still too short!
RLFX is offline
post #8 of 10 (permalink) Old 01-23-2010, 08:38 AM
Noob's Avatar
First Name: Paulo
On my MDF table top, I used 2 coats of polyurethane, sanded with 220 grit (almost baby smoooth!) then put on 2 more coats of poly and some Johnsons wax. You might want to try that on you're fence.
Noob is offline
post #9 of 10 (permalink) Old 06-27-2012, 06:13 PM
First Name: Jerry
Send a message via MSN to jerrag
I did just what you said you were planning, just finished my MDF fence however I cut some slots in it and attached two hardwood facings so I can adjust the width of the opening. I also cut a U into both the table and the base so I can go deep with the router bit should the need arise. I keep watching the reruns of Router Workshop and see what the guys do with their table, I am just itching to do some of that stuff. I even picked up a spacer fence (3/8's ) when Oak Park still had some left (I see they still have the 1/4 inch left on close out but I think they were down to one, the price is right on them, in fact the stuff they have left is getting almost affordable!) I am going to laminate the hardwood facing tomorrow if I can find the left over from laminating our counter tops a few years back, that was my introduction to using a router and I have been router crazzzzzy ever since. I wanted the hardwood facing so I can replace it should they become damaged, I do do stupid things occasionally. I have pictures of my table posted elsewhere on the site under show your router table but I didn't have the fence ready when I took them. Attached a couple here, I made mine out of an old TV stand I picked up at the State Surplus outlet store, cost me 20 bucks for the stand, all made out of MDF, and 7 bucks for the materials to make my fence, well a few bucks would have to go to one of the woodworking online places where I purchased the kit for building jigs, took the mounting screws and knobs out of that package, nice to have that stuff available since I live out in the sticks where they lumberyard guy looked at me like I was an alien or something when I asked for a sheet of MDF. He tried to talk me into particle board, ya that would make a WONDERFUL fence! Any how it is almost done just have to put a finish on every thing, going to put some Johnson's past wax on the top of the table, several coats, like we used to use in the Army on the barracks floor. Same with the laminate when I have it applied.
jerrag is offline
post #10 of 10 (permalink) Old 07-26-2012, 05:28 PM
Country: Uruguay
First Name: N/aLuis
Hi Greg
I did the fence with two pieces of pine, glued and nailed at 90 degress and two pieces of mdf plastic laminate (here is melaminico) in the wood cut four slot and fixed with screw and wing nut, work very well, is recomendable keep 90 degress with the table.
saltapones is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
