Need Help - Router Forums
post #1 of 6 (permalink) Old 01-23-2010, 04:19 PM Thread Starter
First Name: Alan
Default Need Help
Just purchased a PC 7518 and mounted under table. To adjust the router, high and low...it must be turned and the electrical wire is a pain in the a--. What can be done to avoid this???? I can't afford a raiser....my wife will throw me out of the house if another "toy" is purchased.
tks
asrubin is offline
post #2 of 6 (permalink) Old 01-24-2010, 05:02 AM
allthunbs's Avatar
First Name: Ron
tks
I use the OakPark baseplates. All adjustments are done out of the table and it's a snap to pull and replace. Watch the router workshop videos on The Woodworking Channel . You'll also find they're a lot cheaper than other router philosophies.
Allthunbs
allthunbs is offline
post #3 of 6 (permalink) Old 01-24-2010, 11:07 AM
Ghidrah's Avatar
First Name: Ronald
The Router workshop uses modified plunge routers with the plunge springs removed correct? Asrubin mentions "it must be turned", so it appears to be a fixed base eh.
There're hassles with the plunge and fixed base platforms, however, this is something you'll have to put up with until you can afford a lift without wifey killing you in your sleep. The only thing is to pull it out, unplug it, adjust it and reinstall it.
I put up with a non modified 7539 in the RT for 11 yrs. Lifts really come into play with very fast duplication/restoration profile projects.and above the table bit changes.
There are quite a few lifts on the market all vary in price from just over $100 to over $300
Ghidrah is offline
post #4 of 6 (permalink) Old 01-25-2010, 01:53 AM
BigJimAK's Avatar
asrubin,
It may be a bit awkward until you can get a lift but you'll not regret buying that router. I've got one in my table and it's a true production workhorse.
BigJimAK is offline
post #5 of 6 (permalink) Old 01-25-2010, 04:33 AM Thread Starter
First Name: Alan
Thanks for the post.. I had a Dewalt DW610 under the table and it had a screw to raise and lower the unit. It was a pleasure and no hassel. I will look for another router that can be used to replace the PC7518 that I don't have to screw to raise and lower the unit for under the table routing. When I find one I will sell this unit.
Thanks for all posts.
asrubin is offline
post #6 of 6 (permalink) Old 01-25-2010, 05:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
"When I find one I will sell this unit."
You can never have too many routers, like cordless drills, on a big project it's so quick and easy to have routers and drills set up with different size drills/cutters.
We would appreciate it if you could see your way clear to completing your profile.
Harry
harrysin is offline
