Direct mount of router (no plate) - Router Forums
post #1 of 12 (permalink) Old 01-23-2010, 05:09 PM Thread Starter
Default Direct mount of router (no plate)
I'm going to make a new table top router table. I want to keep it fairly light and I was planning on using hardwood ply for the top (3/4" thick).
Rather than using a mounting plate, I was thinking of reducing the thickness of the mounting area (underneath) with my router to 3/8" thickness and mouting the router directly to the table top. This would seem to me to eliminate any leveling issues and sounds like about the same amount of work.
Has anyone done this? Am I overlooking any issues?
The router I am planning to mount is a Hitachi M12V plunge router. I plan on using it to make raised panel doors and cope and stick rails and stiles.
Thanks for looking.
Regards,
Packard
Packard is offline
post #2 of 12 (permalink) Old 01-24-2010, 04:22 AM
I would mount a plate in the table for what you intend to build with it. The panel bit would could be as big as 3-1/2" in diameter. So you would have to have an opening to accommodate the bit. That's a large opening. Having a plate would allow you to use reducer rings for the smaller bits such as the rail & stile bits or flush trim bits. Running a small bit in a big opening would be dangerous & could ruin your material from lack of support around the bit.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 12 (permalink) Old 01-25-2010, 08:11 AM Thread Starter
I have access to 1/4" thick aluminum plates. I think I'll go with that for the mounting plate.
Packard is offline
post #4 of 12 (permalink) Old 01-25-2010, 08:38 AM
SantÚ's Avatar
Country: Belgium
First Name: Daniel
Yes, I have always mounted my routers that way, without mounting plate, (before installing them on lift). Here is a PDF document (in French)
Greetings
File Type: pdf DEFONCEUSE MONTEE SOUS TABLE SANS PERTE DE HAUTEUR.pdf (319.6 KB, 498 views)
Member of the french site for woodworkers
www.lescopeaux.asso.fr
SantÚ is offline
post #5 of 12 (permalink) Old 01-25-2010, 10:15 AM
I will 2nd. James post, by the way Alum.plate is a no no,the Alum.will put marks on the stock and it's a PITA to get them off.
Why would you mount the router without using a plate, you can still pop it out and use it for a hand router,plus you can use the router table for other jobs not just one of them in the shop.
post #6 of 12 (permalink) Old 01-27-2010, 03:18 PM
First Name: Daniel
The first table I made was 1975, my first year teaching. I made it portable so the kids could take it to their bench/vise. It was plywood with a 3/8" relief for the direct mounting of an old Stanley router. They were still using it when I left there after 8 years. I replaced the top once because they wore completely through the top laminate and the router a couple of times.
Dan
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #7 of 12 (permalink) Old 01-27-2010, 04:16 PM
SantÚ's Avatar
Country: Belgium
First Name: Daniel
With this system i can take of my router for hand router or changing the bit in 3 seconds. Go and see the PDF file, you can see that it is very easy because the router is not fixed no way. It stay only with his weight. This way, you do no loose length of bit.
SantÚ is offline
post #8 of 12 (permalink) Old 01-27-2010, 06:31 PM
Hi SantÚ
I did the same thing, but it's a small router ,but it can take on the brass guides (1 3/16 and the 1 1/2" ), see below , but it has a plate not sq. true one but a plate ..
http://www.routerforums.com/jigs-fix...ter-table.html
post #9 of 12 (permalink) Old 01-27-2010, 07:47 PM
schmelifox2's Avatar
First Name: Jerry
My first table was a piece of plywood with a hole in the middle then the router was mounted to a piece of 1/4" hardboard that laminated over the top. The hardboard was cheap and slippery.
schmelifox2 is offline
post #10 of 12 (permalink) Old 01-28-2010, 02:49 AM
SantÚ's Avatar
Country: Belgium
First Name: Daniel
Hi SantÚ
OK, I have seen. I also mounted a big router in this way but after I mounted on a lift. This is more better !
SantÚ
SantÚ is offline
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Marvel 40 Router Plate cbsjoez1935 General Routing 2 04-06-2009 05:23 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
Hitachi M12VC Router Plate kefjens Table-mounted Routing 1 01-02-2009 09:27 AM
