Phenolic vs Aluminum - Router Forums
post #1 of 5 (permalink) Old 01-24-2010, 10:33 AM Thread Starter
Default Phenolic vs Aluminum
Iím planning on getting a cast iron table saw extension and not sure which insert to get Phenolic or Aluminum? I have done a few searches but want to know which is more preferred. I will be placing a Ridgid 2.25 combo router to this table.
Kevin
kma2032 is offline
post #2 of 5 (permalink) Old 01-24-2010, 11:14 AM
Ghidrah's Avatar
First Name: Ronald
I think it depends on the type of phenolic, some are denser/harder than others. I have the Benchdog lift system with the (I think) older aluminum plate which is heavy. I believe the heavier plate helps in dampening vibration.
I'd guess connecting up to the TS will help the dampening effect even more.
Ghidrah is offline
post #3 of 5 (permalink) Old 01-24-2010, 11:24 AM
Hi Kevin
You may want to take a hard look at the link below,they come with the right plate to mount the router in place..
Table Saw Accessories - Peachtree wooding Products
Kevin
post #4 of 5 (permalink) Old 01-25-2010, 01:33 PM
First Name: Dirk
Hi Ho: As usual, it is a matter of personal choice and cost. The cast iron table is a large investment in either time or money (or both). The plate will cost between $25 and $70 depending on where you get it and whether phenolic or aluminum. If this is a small amount compared to the table I'd go with an aluminum plate because I don't like to machine phenolic. (Aluminum is easy) Aluminum is also stronger, but it does cost more.
Either will work for a router the size you suggest, but you may eventually want a bigger router?
Dirk
dirko is offline
post #5 of 5 (permalink) Old 01-25-2010, 01:59 PM Thread Starter
Thanks dirko that was the what kind of info I was looking for I've never used an aluminum plate before so I wanted to know peoples opinion.
Kevin
kma2032 is offline
Milwaukee 5615 Aluminum Table Plate Help pottsgo Table-mounted Routing 7 10-09-2011 11:41 AM
aluminum plate insert The Illustrator Table-mounted Routing 8 04-04-2009 09:08 PM
routers and aluminum fishski13 General Routing 0 01-18-2009 12:52 AM
Phenolic Color cbsjoez1935 General Routing 3 04-19-2007 01:45 PM
working with aluminum mpphoto Table-mounted Routing 9 05-10-2006 07:12 PM
