Router as jointer? - Router Forums
post #1 of 28 (permalink) Old 01-24-2010, 03:13 PM Thread Starter
Default Router as jointer?
Is there a good way to use a table router to get a smooth, straight edge on a rough-sawn board?
fishlore is offline
post #2 of 28 (permalink) Old 01-24-2010, 03:49 PM
BrianS's Avatar
First Name: Brian
Yes, there is.
It all depends upon what type of fence you have as to what method you need to follow. Basically, you need to make the outfeed side of the fence stick out further (about 1/32 to 1/16 is plenty) then the infeed side. Zero out the bit to the outfeed side, and then run your stock. Make sure you apply pressure to your stock on the outfeed side.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 28 (permalink) Old 01-24-2010, 04:13 PM
Originally Posted by BrianS View Post
Yes, there is.
Yes, an easy way to do this is to apply a strip of Formica to the outfeed side which will give you the required differential.
Packard is offline
post #4 of 28 (permalink) Old 01-24-2010, 09:54 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Bill, I agree with both the above answers but for "not applicable's" one you would have to make a dedicated fence, which is no big deal.
Harry
harrysin is offline
post #5 of 28 (permalink) Old 01-25-2010, 06:20 AM Thread Starter
Default Thanks!
Brilliant! Thanks for saving me several hundred dollars on a jointer I don't need now and don't have room for anyway
fishlore is offline
post #6 of 28 (permalink) Old 01-25-2010, 07:27 AM
allthunbs's Avatar
First Name: Ron
I've been trying this for quite some time now and have yet to pull it off successfully. Please do a pictorial essay on it so maybe I can see what I'm doing wrong ;-)
I got so fed up I bought a jointer.
Allthunbs
allthunbs is offline
post #7 of 28 (permalink) Old 01-25-2010, 07:54 AM
First Name: Jonathan
There are problems using a router table as a jointer. The TDC of the arc of the bit should be precisely (plus or minus .002 would be nice, but not likely) the same as the outfeed part of the fence. Setting that up takes a lot of time, and you'll always be using the table for other things besides jointing.
I understand about needing more room & cost, but even a small well built jointer will make woodmorking a lot nicer.
Slingshot is offline
post #8 of 28 (permalink) Old 01-25-2010, 08:36 AM
harrysin's Avatar
First Name: Harry
As has been suggested, a simple dedicated fence with Laminex glued to the out feed side is all that's necessary. There is however one BIG disadvantage, not many cutters give much more than a 2" cut, whereas the average jointer covers 6".
Jonathan, could you elaborate on the TDC of the arc statement, I'm sure that I'm not the only puzzled one here.
Harry
harrysin is offline
post #9 of 28 (permalink) Old 01-25-2010, 08:45 AM
Gene Howe's Avatar
First Name: Gene
My router infeed and out feed fences are separate and adjustable so I just push the outfeed fwd.
A good straight edge across the out feed and the bit assures correct depth.
And, of course a spiral cutter is your friend in this process. With a spiral, TDC isn't a concern. At least, in my experience.
Gene
Gene Howe is offline
post #10 of 28 (permalink) Old 01-25-2010, 11:39 AM
Mike Wingate's Avatar
First Name: mike
I am happy with mine, but as stated the drawback is the height of the cutter, around 50mm/2".
Mike Wingate is offline
Replacing Router paerley General Routing 11 01-22-2010 12:49 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Ridgid Router Easy Above Table Bit Change shawnpatt Table-mounted Routing 1 03-06-2009 04:58 PM
