Adjustment Ring on PC 7518 - Router Forums
post #1 of 3 (permalink) Old 01-27-2010, 06:00 AM Thread Starter
First Name: Alan
Default Adjustment Ring on PC 7518
I mounted my PC 7518 under table. Now I cannot see the ring on the fixed base to make adjustments. Is there any way to turn the adjustment ring over to see the measurments numbers?
thanks
asrubin is offline
post #2 of 3 (permalink) Old 02-01-2010, 04:56 PM
dutchman 46's Avatar
First Name: Howard
I can not answer that question. Does the router pop out of the opening? Can you make adjustments that way? It's not the only solution, You may have to move it with out viewing. You can also use guage bars.
John 3:16
dutchman 46 is offline
post #3 of 3 (permalink) Old 02-01-2010, 05:05 PM
Hi asrubin
No ,it go's on just one way, that's why many that have the big PC put them in a lift device..
thanks
Craftsman 315.175040 Router Depth Adjustment gloftis Starting Off 8 05-02-2020 06:52 AM
Need a router w/ accurate and easy height adjustment in table use. WoodTroll Table-mounted Routing 26 04-10-2011 12:11 PM
Bosch 1617 ESV fine adjustment question horn man General Routing 5 01-21-2010 05:07 PM
Reducing Ring AnthonyBklyn General Routing 6 05-28-2009 11:45 AM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
