What kind of hing to use? - Router Forums
post #1 of 4 (permalink) Old 01-29-2010, 07:01 PM Thread Starter
First Name: Daryl
Default What kind of hing to use?
In order to access the router, my router table top will be hinged at the edge where it meets the table saw top. I need a fairly tight joint when in the lowered position (obviously) an I need the hinges to not stick up above the surface. What kind of hinge would I use for this? Or what other solutions are there?
sofasurfer is offline
post #2 of 4 (permalink) Old 01-29-2010, 07:20 PM
Hi
I would suggest the cabinet hinge type below, easy to setup and install, all the hardware is down under the plate (top) when it's down.
Name:	old router table A.jpg
post #3 of 4 (permalink) Old 01-29-2010, 07:50 PM Thread Starter
First Name: Daryl
Thanks. I that seems to be what I am looking for.
post #4 of 4 (permalink) Old 01-29-2010, 07:55 PM
Your Welcome
You will see the Alum.pockets for the hinges but you can make some out of hardwood that should do the job just fine..
What kind of wood for routing signs BC Wood Worx Sign Making 22 10-06-2011 12:09 PM
What kind of paste wax? kartracer63 Tools and Woodworking 12 04-12-2009 09:02 AM
If you were growing trees, what kind would you grow? Jeremiah Lobby 37 03-08-2009 01:54 PM
What Kind Of Fit Do You Like.... challagan Jigs and Fixtures 12 06-11-2007 06:13 AM
what kind of finish Glenmore Woodturning and Lathes 3 09-12-2006 09:11 PM
