stile and rail bits, - Router Forums
post #1 of 12 (permalink) Old 01-29-2010, 10:03 PM Thread Starter
Default stile and rail bits,
hey guys i have a cheapo set of stile and rail bits but i hate them so im going to buy a good set, im looking at freud or bosch which do you guys think is better and how do you tell how thick of stock it will cut i know some are half and some 3/4 i want the three quarter but im not sure what dimensions that are given that tells you that i have looked at sets and they give a bunch of dimensions on everything but its kindof confusing to me thanks guys, the reason for wanting diffrent bits is my bits do not allow a snug enough fit for me, the one cuts to thick and deep and the other is the opposite so when u go to match them there is about a 1/16 of an inch gap inbetween them because one of the cutters doesnt cut deep enough, hopefully someone can make sense of what i have just tryed to explain.
torence20 is offline
post #2 of 12 (permalink) Old 01-29-2010, 10:09 PM
The bit set below will cut 1/2" deep just like a shaper bit set.
Raised Panel Rail & Style Bit Set-Sommerfeld's Tools For Wood
http://www.sommerfeldtools.com/Arche...ductinfo/DVD1/
post #3 of 12 (permalink) Old 01-29-2010, 10:18 PM
First Name: Daryl
There are also differant types of r&s bits...stacked, matched, etc...at least I think those are some of the proper terms I have seen.
My question is this... are there instructions, or a website or anything where it tells how to use the various types of router bits that may not be so obvious, and how to set them up?
Just looking for some interesting reading?
sofasurfer is offline
post #4 of 12 (permalink) Old 01-29-2010, 10:42 PM
Ji
Get the sommerfeld video if you can swing it get his set, you will be glad you did ..
Complete 8 How-To-Do Dvd Set-Sommerfeld's Tools For Wood
post #5 of 12 (permalink) Old 01-29-2010, 11:09 PM
+1 on BJs recommendation. Very informative info in the videos.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 12 (permalink) Old 01-29-2010, 11:34 PM
RustyW's Avatar
First Name: Rusty
Here is some good information on using R&S bits.
http://www.mlcswoodworking.com/shops...lstile0911.pdf
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #7 of 12 (permalink) Old 01-30-2010, 09:59 AM
Country: Sweden
First Name: bill
Here is a list of PDF instruction sheets from CMT, very detailed and highly reco'd.
http://www.cmtutensili.com/viewdoc.asp?pars2=28~133~5
"I don't believe anything, but I have a lot of suspicions"
-R.A.W.
laxknut is offline
post #8 of 12 (permalink) Old 01-30-2010, 04:45 PM Thread Starter
i know how to use the bits i just dont like the quality of the bits, i can get a very nice finished product but i have to do to much b.s to get to that stage because of the quality of the bit set so i need to know which to buy frued or bosch they are about the same price for the ogee stile and rail 1/2 shank
post #9 of 12 (permalink) Old 01-30-2010, 05:02 PM
Hi torence
Sounds like you have your mind set, I would go with the Freud over the Bosch bits..
" i know how to use the bits " you must know about the trick, how to switch the bits out so all the joints come out right on the button without any sanding needed or to cut your time in half making the frames.
post #10 of 12 (permalink) Old 02-01-2010, 03:24 PM
I have the Bosch bits and have been very satisfied with them. I went with Bosch becasue I don't have a variable speed router, and their maximum bit RPM is 27,500 which is the speed of my PC router.
Sawatzky is offline
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 15 07-11-2011 05:16 PM
Bits to use for a square or plain rail and stile? azw Router Bits - Types and Usage 6 01-17-2010 03:02 PM
Stile and Rail bits, whiteside or rockler whtteg Router Bits - Types and Usage 6 07-31-2009 06:53 AM
Hi all -- rail and stile bit and 1/2" collet help! Bryan Router Bits - Types and Usage 16 03-31-2009 10:28 PM
Ogee Stile & Rail Bits set up tips? donald201 Router Bits - Types and Usage 11 02-14-2009 11:55 PM
