Question for R/T lift owners - Router Forums
post #1 of 9 (permalink) Old 01-31-2010, 03:24 PM Thread Starter
First Name: Paul
Default Question for R/T lift owners
I would like to build a router cabinet before my new lift arrives. I ordered the PRL-V2 and it is presently on backorder. As I was drawing up the plans I realized that I had no idea how much space would be required for the router lift. I would like to have ample room for drawers on either side of the section housing the lift.
My thoughts right now, based on photos, would be 10"w by 10"d by the depth of the cabinet (23"). Would this space be enough for the lift and router?
Paul
Paul Stroik is offline
post #2 of 9 (permalink) Old 01-31-2010, 03:51 PM
Hi Paul - welcome to the forum-
As long as you already have one on order I would think a phone call to Woodpecker would get you the information.
John Schaben
jschaben is offline
post #3 of 9 (permalink) Old 01-31-2010, 05:01 PM Thread Starter
First Name: Paul
Yes it would. Just thought I'd ask those who already built their cabinets.
post #4 of 9 (permalink) Old 01-31-2010, 06:36 PM
TwoSkies57's Avatar
Paul, it has as much to do with the router as well as the lift. The router will extend well below the bottom of the lift. the attached photo's are of my PRL-v2 with a Milwaukee 5625 installed. If you need more of an idea as far as the cabinet goes. try my thread on the cabinet I built..
http://www.routerforums.com/table-mo...ble-setup.html
Its a fantastic lift, i have very few issues with it...not sure which one you got, but if you got the metal inserts, give them a good waxing as soon as you get them. Mine all tarnished within a few days...
TwoSkies57 is offline
post #5 of 9 (permalink) Old 01-31-2010, 07:05 PM
Ghidrah's Avatar
First Name: Ronald
There are tons of RT prints out there and as many RT cabinet prints let alone stick builds unrelated to any store bought schematics.
There are a few options to consider regarding the cabinets interior dimensions for an outlet, table top clampdowns, lift/router combo height and diameter.
Even though you'll rarely need to pull the lift combo out, smooth removal and replacement is almost as important as ease of operation
Ghidrah is offline
post #6 of 9 (permalink) Old 01-31-2010, 07:10 PM Thread Starter
First Name: Paul
Bill - Thank you for that info. That is precisely what I was looking for. And the Milwaukee 5625 just happens to be the Router I will be installing in the PRL-v2. I guess I did fail to mention that initially.
Your cabinet also included ideas I am considering. One of which is full extension slides. That or wooden slides which would give me a little extra drawer space.
Can't believe I didn't notice that thread during my research.
Again, thanks for the info and photos.
post #7 of 9 (permalink) Old 01-31-2010, 07:13 PM
TwoSkies57's Avatar
My pleasure Paul... if ya need anything, drop me a note..
post #8 of 9 (permalink) Old 01-31-2010, 07:19 PM
Hi Paul
On the one I have installed I use a floating shelf ( the pin type holding the shelf )so to speak, I can move it up or down to fit any router I put in the cabinet, you just never know what router you may want to put in the cabinet, once it's glued in place that's it , the one I'm now using needs 16" of room to use it to the max.
Paul
post #9 of 9 (permalink) Old 01-31-2010, 09:37 PM Thread Starter
First Name: Paul
Thanks BJ and Ron. I have noted those bits of info on my plan sheet. Almost forgot about the outlet/switch installation and its placement.
Question: Big Jack vs. Router Lift: When to choose each? BigJimAK Table-mounted Routing 0 08-07-2009 03:45 AM
Lift question Tony_J Table-mounted Routing 15 05-04-2009 07:50 PM
Router Lift Question twilite Table-mounted Routing 13 12-22-2008 10:26 AM
