pin router switch plates - Router Forums
post #1 of 5 (permalink) Old 02-07-2010, 07:30 PM Thread Starter
Default pin router switch plates
built the pin for the router table. works great for the plug plates with a 1/4 inch cutter. using a 1/8 inch cutter for the relatively small hole in the switch plates and I'm getting flex in the cutter. it is a single flute cutter so that may be the problem any ideas? short end mill perhaps? roto zip type cutter?
maineshops is offline
post #2 of 5 (permalink) Old 02-07-2010, 07:44 PM
Hi
You can use the 1/4" bit and than use the 1/8" after,, it's best to get a high end 1/8" bit, the one that comes with many inlay kits works well, it's made to do many jobs. buy two the bits do like to break easy.. but for 10.oo bucks it's hard to beat the price on the bit.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
post #3 of 5 (permalink) Old 02-10-2010, 07:57 AM Thread Starter
got some new1/8 2 flt cutters. they work better but not good. i can do the plug holes just fine with the 1/8 cutter. i'm going to try to drop the cutter speed and see if that helps
post #4 of 5 (permalink) Old 02-10-2010, 09:34 AM
Hi
I must press the point about using the right bit and don't pull the speed down, crank it up to high..let the bit do the work and it will.. just like cutting butter..
Spiral Upcut and Downcut Router Bits
MLCS solid carbide router bits
post #5 of 5 (permalink) Old 02-12-2010, 07:32 AM Thread Starter
i'll try an end mill and see if that helps
switch plates? maineshops Table-mounted Routing 3 02-05-2010 07:48 PM
Router and switch question jpr28056 Table-mounted Routing 20 01-21-2010 07:09 AM
Good place to buy router plates Gathion Table-mounted Routing 5 07-26-2009 09:31 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
