Bench Dog Pro Top Contractor bit opening - Router Forums
post #1 of 2 (permalink) Old 02-15-2010, 06:36 PM Thread Starter
First Name: Ed
Default Bench Dog Pro Top Contractor bit opening
In reading the brochure on this table all I could find where it mentioned the insert size was 2 inches, but no mention of others. So I called to ask them and the tech support guy said the opening is indeed fixed at 2" and the that size is it-the table doesn't accept other sizes.
Is that indeed the case and has that worked out OK for any of you that own this table?
biggdogg is offline
post #2 of 2 (permalink) Old 02-16-2010, 08:33 AM
Ghidrah's Avatar
First Name: Ronald
I don't know about the BDP cont table, limiting the throat to 2" seems a bit restrictive. But considering that there are many vertical panel bits out there it might not be an issue if you're will to go vert.
I have the BD Pro lift, it comes with 3 inserts, the smallest opening reduces to 2" and it has the ability to accept inserts, (plastic I think), I never bought any of the zero clearance inserts.
To change the subject a bit, have you considered building your own table? There are many free and pay for prints that'll give you much bang for the buck.
Ghidrah is offline
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
new router and saw bench opelblues Lobby 1 09-14-2008 06:29 AM
Bench Dog Files Chapter 11 Bankruptcy jennofarc Tools and Woodworking 12 11-18-2007 03:08 PM
Bench sized powertools JTsteelblu Tools and Woodworking 3 10-13-2004 01:31 PM
