Double sided tape - Router Forums
 3Likes
post #1 of 12 (permalink) Old 02-26-2010, 07:35 AM Thread Starter
First Name: Alan
Default Double sided tape
What brand of double sided tape is used to attach to wood surface for sticking two pieces together? I have been using a two sided but on one piece it is very hard to remove. This is just for routering then I will remove the wood.
tks
asrubin is offline
post #2 of 12 (permalink) Old 02-26-2010, 07:43 AM
Cochese's Avatar
First Name: C
I just used whatever carpet tape they had at the Borg. There was a little residue, but nothing that couldn't be cleaned up.
Cochese is offline
post #3 of 12 (permalink) Old 02-26-2010, 07:47 AM
First Name: del
try rolling the tape with finger instead of trying to pull it off That work's quite well for me
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 12 (permalink) Old 02-26-2010, 08:22 AM
First Name: Danny
I use the foam stuff that they have at HD, it is usally red, and I just roll it as mentioned above and it comes right off.
jd99 is offline
post #5 of 12 (permalink) Old 02-26-2010, 04:58 PM
First Name: Gary
I use double sided masking tape used to install golf club grips or carpet tape if I need more hold.
garybaritone is offline
post #6 of 12 (permalink) Old 02-26-2010, 05:27 PM
levon's Avatar
First Name: levon
manco seems to be the best
levon
levon is offline
post #7 of 12 (permalink) Old 02-27-2010, 01:36 PM
First Name: Daniel
I have used two different ones: double-sided masking tape from 3M or Spec-tape and double sided cloth tape kinda like the old duct tape, but double-stick. I just made corian table saw table inserts using the cloth type and it worked great.
bpraney and Semipro like this.
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #8 of 12 (permalink) Old 02-28-2010, 12:20 AM
DerekO's Avatar
First Name: Derek
corian table saw inserts. Neat.
bpraney likes this.
DerekO is offline
post #9 of 12 (permalink) Old 09-01-2015, 12:03 PM
Here is some good tape that holds well and no residue left after use.
http://www.routerforums.com/woodwork...late-tape.html
woodman79 is offline
post #10 of 12 (permalink) Old 09-01-2015, 12:16 PM
Semipro's Avatar
First Name: John_*
Semipro is online now
Double Sided Tape? Router is still my name Portable Routing 13 06-18-2010 05:50 PM
Best Way to Remove Shurtape (double sided tape) Residue rstermer General Routing 9 12-13-2009 09:45 AM
Double sided tape sankarmohan Lobby 16 12-11-2008 10:31 PM
double sided tape? falcn63 General Routing 4 01-17-2006 01:48 PM
Brads VS. Double Sided Tape Pop_pop1 Jigs and Fixtures 8 08-18-2005 05:11 AM
