Phenolic or Aluminum - Router Forums
post #1 of 34 (permalink) Old 02-27-2010, 06:11 PM Thread Starter
First Name: Steve
Question Phenolic or Aluminum
Hi, I am wanting to build a router table but not sure which is a good insert. Is it just personal choice or is there a significant difference between phenolic inserts or ally ones. I have looked at a few from, kreg,woodpecker,axminster ar even a trend RTI, why so much choice, life is supposed to be simple.
Any pointers or pitfalls to watch out for.
doddy is offline
post #2 of 34 (permalink) Old 02-27-2010, 06:57 PM
Soapdish's Avatar
First Name: Jake
I wouldn't use aluminum if its not anodized, but having said that, if you coat it with paste wax then maybe there wouldn't be the "marking" problem. Just my 2 cents, im no pro or expert.
My favorite thread on routerforums.com. Great Posts
Soapdish is offline
post #3 of 34 (permalink) Old 02-27-2010, 07:02 PM
+1 on the anodizing... Most of the name brands are... About the only really functional difference I can think of is Phenolic are generally 3/8 thick and AL are 1/4". Difference of 1/8" depth of cut.
John Schaben
jschaben is offline
post #4 of 34 (permalink) Old 02-27-2010, 08:03 PM Thread Starter
First Name: Steve
So in general theres no diference, they both do an adequate job its just a personel choice and cost.
thanks for the input
doddy is offline
post #5 of 34 (permalink) Old 02-28-2010, 12:02 AM
DerekO's Avatar
First Name: Derek
"marking problem" is that anything like how I had marks from the feet of the router table on my table saw before I started putting something on top of the table before using it? Aluminum saw table top...think router table top too. I have since waxed and buffed out the table top. Should probably do it again soon.
DerekO is offline
post #6 of 34 (permalink) Old 02-28-2010, 03:21 AM
Mike Wingate's Avatar
First Name: mike
Annodized aluminium is great until it gets scratched,then visually is looks awful. Phenolic works. I have both. They both make good inserts and are good materials for making and using as router tools.
Mike Wingate is offline
post #7 of 34 (permalink) Old 02-28-2010, 04:53 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The last plate that I made for a 1/2" Bosch router was from the bottom corner of this 3.5mm Aluminium painted plate and it was fine, no sag whatsoever.
Harry
harrysin is offline
post #8 of 34 (permalink) Old 02-28-2010, 05:19 AM
Stefang's Avatar
First Name: mike
I think between the two that aluminum would maybe be a little stiffer, but I've heard a lot of good things about phenolic too. Sounds like a luxury problem to me.
Mike, an American living in Norway
Theory is when one knows everything, but nothing comes out right.
Experience is when everything comes out right, but no one knows why
In my shop theory and practice are united. Nothing comes out right and nobody knows why.
Stefang is offline
post #9 of 34 (permalink) Old 02-28-2010, 10:15 AM Thread Starter
First Name: Steve
Thanks for all of your input, i think it is just the cosmetic look then that people go on, as there does not seem to be any strength issues between the two, both are well capable of dealing with what they are designed for, Routing.
Remember, if you don't ask, you won't find out.
Thanks again,
steve
doddy is offline
post #10 of 34 (permalink) Old 02-28-2010, 10:46 AM
I started with Phenolic and replaced it with aluminum because of sagging. My advice is to spend a little extra and use aluminum. Good luck.
sparky1945 is offline
Milwaukee 5615 Aluminum Table Plate Help pottsgo Table-mounted Routing 7 10-09-2011 11:41 AM
Phenolic vs Aluminum kma2032 Table-mounted Routing 4 01-25-2010 01:59 PM
routers and aluminum fishski13 General Routing 0 01-18-2009 12:52 AM
Phenolic Color cbsjoez1935 General Routing 3 04-19-2007 01:45 PM
working with aluminum mpphoto Table-mounted Routing 9 05-10-2006 07:12 PM
