pivoting fence, small profiles? - Router Forums
post #1 of 6 (permalink) Old 03-01-2010, 08:29 PM Thread Starter
Default pivoting fence, small profiles?
Hi everyone,
I'm planning on making a VERY simple table for a small trim router so I can make miniature wood trim for architectural models. I've seen a photo of one that has one end of the fence connected to the table with a knob to tighten and the other side of the fence swings free, just clamped where needed. I've seen this kind of setup on larger tables too, is there an advantage or disadvantage to this setup rather than having the whole fence able to move (assuming I know I will only be using it for very thin pieces of wood and won't need the extra room behind the cutter)
Also, does anyone have any suggestions or safety tips for working with thin pieces of wood like this? For example, my "crown molding" will be 3/8" thick, and "baseboards" may only be 1/8" or less, both around 3/8" wide and 24" length. I'm thinking I'll need to tape/glue the pieces to be cut onto a larger board for the cut. Anyone working with very small profiling cuts like this?
Thanks everyone, great info on this site!!
Dan
deacon76 is offline
post #2 of 6 (permalink) Old 03-01-2010, 08:49 PM
Hi Dan
I have a router setup that way and it works great with the swing fence,if you click on my Gallery you can see pictures of it..I use it for the small jobs .
small swing fence below
http://www.routerforums.com/jigs-fix...ter-table.html
Originally Posted by deacon76 View Post
Hi everyone,
Dan
post #3 of 6 (permalink) Old 03-01-2010, 08:50 PM
I use the pivot on my fence all the time. It does not matter what angle your fence sits at on the table. The fence is always referenced from the center of the bit.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 6 (permalink) Old 03-02-2010, 12:09 AM
BigJimAK's Avatar
Dan... a safety tip. When making small pieces, route as much as possible before cutting the small piece away from something larger. For example, if you want to make a 4" long piece of trim that's 1/8" x 1/8" with a 1/16" round-over bit, use a board that's 1/8" thick and 4" or longer, but perhaps 6" wide. After cutting the profile, rip it to 1/8" width on a table saw. It keeps your fingers further from the bit.
BigJimAK is offline
post #5 of 6 (permalink) Old 03-02-2010, 08:26 AM Thread Starter
Thanks for the replies. I think I'll go ahead and try the pivot fence idea, just for simplicity's sake.
Great idea Jim, I don't know why I didn't think of that. Thanks very much...
Dan
deacon76 is offline
post #6 of 6 (permalink) Old 03-02-2010, 12:15 PM
Hi Dan
With the swing fence and the 1/8" shank router bits you can make all the small stuff you want easy and safe
I got my set from Grizzy at 18.oo bucks if I recall.
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 03:22 AM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
