routing safely. - Router Forums
post #1 of 5 (permalink) Old 03-07-2010, 08:32 AM Thread Starter
First Name: Ken
Default routing safely.
I just made my first RT and my first project is to make a few picture frames.
The wood I'm using is 3/4" X1 1/2"X4' pine,I'm hesitant to route the 1.5" side since it's 4 foot long,I have no t-tracks on the table or the fence(both DIY) to attach featherboards.
How do I do these 4 foot long pieces safely?do I make my own guides and clamp them to the top and the fence?or should I first make the tracks add t-tracks,then attach a featherboard to the top and one on the fence?
I appreciate your help.
Ken.
distrbd is offline
post #2 of 5 (permalink) Old 03-07-2010, 09:13 AM
Hi Ken
Just clamp a true 2 x 4 to the fence to hold the stock down and one to the top of the router table to keep the stock to the fence and use a push stick to get it by the bit safe..
Ken.
post #3 of 5 (permalink) Old 03-07-2010, 09:43 AM
First Name: Greg
I haven't tried it...but Derek posted this brilliant method a while back, and it seems like it would work well for what you are trying to do
Router Forums - View Single Post - Simple way to make small mouldings.
Greg
gregW is offline
post #4 of 5 (permalink) Old 03-07-2010, 12:56 PM Thread Starter
First Name: Ken
Hi Ken
I just tried it and it worked like a charm,thank you for your easy solution I will try to do what GregW mentioned but your way was fast enough and did not involve cutting a groove in a straight piece of wood (and large enough to grab the stock piece tight),I will give a shot later.
Thank you both for great suggestions.
Ken.
distrbd is offline
post #5 of 5 (permalink) Old 03-07-2010, 05:27 PM
Your Welcome Ken
Sometime the easy way is the best way
Ken.
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
New to Routing and already lost!!! sarahrodgers New Member Introductions 10 12-31-2012 11:30 PM
Routing + Template Confusion prav1988 General Routing 8 05-27-2009 08:54 AM
Pattern Routing With Hard Wood -- Safely!!! richnj General Routing 8 12-20-2008 09:32 PM
