Router base plate - Router Forums
post #1 of 31 (permalink) Old 03-28-2010, 06:53 AM Thread Starter
First Name: Swallow
Send a message via MSN to Swallow Send a message via Yahoo to Swallow
Default Router base plate
Well it's getting to the point with the new RT that I had to find some material for the base plate. I've gone through the threads and read the pros and cons of Aluminum vs Phenolic, buying vs making and the benefits of Lexan. I have decided to go with Aluminum if for no other reason than that I have access to large amounts of it and the machining of it is no problem. The Aluminum plate that I will be using is 3/4" thick 10"x14" 70-75-T6 aircraft aluminum tool plate.
I have two choices on mounting the router to the plate,one is to machine a recess into the plate the exact size of the router base and then screwing the base plate to the router in the conventional way and two is to first machine steel posts to fit the plunge holes in the router body and then press fit them into slightly undersized holes in the aluminum plate. I really don't see a problem with this as the spring mechanism is not required and would make changing over to hand held very easy. And using the second method there would be no loss of cutting height as the Makita 3612 base already stands 3/4" proud.
On the top side its just a matter of machining in a 4x 1/4" deep recess with a 3.5" through hole to fit the aluminum, HDF or acrylic inserts.
How about some feedback on this.
And oh yes the edges will be machined as will the top surface. Top will be surfaced down perhaps 30 thou for cleanup.
Name:	router plate 001.jpg
Name:	router plate 004.jpg
Name:	router plate 007.jpg
Retirement is easy, but You really have to work at it.
Swallow is offline
post #2 of 31 (permalink) Old 03-28-2010, 07:57 AM
iamwelty2's Avatar
First Name: Terry
I think I like your approach... I bet you won't have a sagging problem... wish I had access to your equipment!!
iamwelty2 is offline
post #3 of 31 (permalink) Old 03-28-2010, 08:07 AM
dutchman 46's Avatar
First Name: Howard
Hello Swallow! The aluminum that You are using, is quite thick. I must tell You that if it isn't tempered, It will be to soft. It is going to be strong enough. but it will not give You bit depth than the Phenolic will. I have aluminum that is tempered, and it seems to work great, but it is only about 3/16 thick. I would not use the aluminum if it's to thick. As it is, there are bits thst are to short. You must buy wisely.
John 3:16
dutchman 46 is offline
post #4 of 31 (permalink) Old 03-28-2010, 09:36 AM Thread Starter
First Name: Swallow
If you read my post you would see that the Aluminum that I am using is 70-75-T6 and that is about as hard as it needs to be.
Swallow is offline
post #5 of 31 (permalink) Old 03-28-2010, 11:42 AM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi
on the aluminium plate , you can glue a phenolic (Formica ?) plate, you only lose 1mm.
i did so on the base of my tilt router
Cheers
Santé
Name:	DSC01046 [640x480].JPG
Member of the french site for woodworkers
www.lescopeaux.asso.fr
Santé is offline
post #6 of 31 (permalink) Old 03-28-2010, 01:53 PM
Hi Daniel
(picture) That setup is very unsafe , I do many strange things with the router table but I would not try that one.. looks like a great way to snap bits off.
They make and sale bits just for that type of job.
Chamfer Bits
http://www.mlcswoodworking.com/shops.../bt_chamf.html
Originally Posted by Santé View Post
Hi
Cheers
Santé
post #7 of 31 (permalink) Old 03-28-2010, 02:04 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi Daniel
Chamfer Bits
MLCS Chamfer Router Bits
Hi Bob
I don't understand ! I don't see why this router is more dangerous than an other !
Will you explain ?
Daniel
Santé is offline
post #8 of 31 (permalink) Old 03-28-2010, 04:19 PM
TwoSkies57's Avatar
Swallow...
dang boy, 3/4" thick? I thought I was big on overkill.. *S*.. I take it you have all the tooling necessary to do the machine work yourself? I like plan A....
TwoSkies57 is offline
post #9 of 31 (permalink) Old 03-28-2010, 04:38 PM
AxlMyk's Avatar
You could resaw that 3/4" plate and make 2 out of it.
AxlMyk is offline
post #10 of 31 (permalink) Old 03-28-2010, 05:21 PM
allthunbs's Avatar
First Name: Ron
Hi Bob
Will you explain ?
Daniel
Bonjour Daniel:
The way your router bit is set is not a problem. There is a pocket screw cutter that uses 1/4" bits with the exact same motion as you are using. Further, most router bits are made for sideways motion.
Comprends-tu?
Allthunbs
allthunbs is offline
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Router Base Plate Question dabeeler Table-mounted Routing 3 12-24-2008 01:21 PM
