Dumb Question #412 - Router Forums
post #1 of 15 (permalink) Old 04-03-2010, 11:02 AM Thread Starter
jrprottas's Avatar
First Name: Jeff
Default Dumb Question #412
Ok Can you use a lift or other device to use your table mounted router as an upside down plunge router? In other words, lift your spinning router bit into your workpiece at a precise location in the middle of the wood?
This may be the whole point and very obvious. Thanks in advance for not asking me to leave.
jrprottas is offline
post #2 of 15 (permalink) Old 04-03-2010, 11:45 AM
Seems like to much work & need to many hands to accomplish. Just make several passes increasing depth on each pass till final depth is reached. You can use start & stop blocks so you don't over shoot your measurements. If you want the plunge function I would do it off the router table. You can use a plunge router or a fixed base if you do not have a plunge. I still would not try to take to big of a chunk out in one pass.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 15 (permalink) Old 04-03-2010, 12:47 PM
AxlMyk's Avatar
It can be done. Some have mounted a foot pedal that lifts the router when you step on it. It causes a dowel to push the router up, much like the foot pedal on a piano. Motorized lifts can also do it.
AxlMyk is offline
post #4 of 15 (permalink) Old 04-03-2010, 01:33 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi,
You can see the one i made myself at this adress
http://www.lescopeaux.asso.fr/Techni...Defonceuse.pdf
Cheers
Santé
Member of the french site for woodworkers
Santé is offline
post #5 of 15 (permalink) Old 04-03-2010, 02:50 PM
Hi Jeff
Yes, I do it all the time with the motorized lift but it can be done with the hand crank also..very easy job.. you can make a simple slip on block for a stop block to get it to stop at the same point every time..
post #6 of 15 (permalink) Old 04-03-2010, 04:51 PM
curiousgeorge's Avatar
First Name: George
Jeff,
Check this site out. John Nixon has teamed with MLCS to make and offer his motorized lift. There is also a video to watch it in action.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #7 of 15 (permalink) Old 04-03-2010, 05:04 PM
TwoSkies57's Avatar
OK, thats it Jeff, your outta here,,,
Reason: "exceeding the posted dumb question limit".......
Just kidding brother.... remember, the only real dumb question, is the one that doesn't get asked!! so ask away!!!!
TwoSkies57 is offline
post #8 of 15 (permalink) Old 04-03-2010, 08:25 PM Thread Starter
jrprottas's Avatar
First Name: Jeff
Default Thanks Curious
Originally Posted by curiousgeorge View Post
Jeff,
You sure satisfied my curiosity-that MLCS unit is going to be awesome! Now I just get to obssess for months...
post #9 of 15 (permalink) Old 04-04-2010, 07:19 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This pedal is so easy to make, it was based on one made from wood. The third and fourth shots indicate how fast and accurate dowelling is, mortices too are just as simple (and accurate)
Harry
harrysin is offline
post #10 of 15 (permalink) Old 04-04-2010, 07:44 AM
AxlMyk's Avatar
Thanks Harry. That's the idea I mentioned, just couldn't find a thread on it.
AxlMyk is offline
New Whiteside bit set - dumb question Eusibius2 Router Bits - Types and Usage 11 03-03-2010 01:17 AM
Dumb Question Melvin Table-mounted Routing 15 11-18-2009 08:06 AM
Dumb Question Caseyjones906 General Routing 2 08-29-2006 01:57 PM
making a clear subbase- dumb question rprice54 General Routing 4 01-16-2006 04:22 PM
