Porter Cable router #7529 - Router Forums
post #1 of 15 (permalink) Old 04-03-2010, 03:30 PM Thread Starter
First Name: Ken
Default Porter Cable router #7529
I did search here and other sites but not many people have this model,it's a plunge router but I would really like to attach it under a PC router table .
I managed to do it with a lot of difficulty for one single reason :I can not remove the springs which as you can imagine it makes it hard to adjust not impossible but very hard.
Does anyone have this router mounted in a table? how did you remove the springs?what's the alternative? buying a router raiser?
It seems to be a very good router but too heavy for me to use hand held due to an old shoulder injury.
If you have any idea/comments please share with this newbie who appreciates it immensely.
Regards.
Ken.
distrbd is offline
post #2 of 15 (permalink) Old 04-03-2010, 03:53 PM
Hi Ken
Many of the PC routers are setup the same way the link below may help you take them out.
Router Workshop: Spring Removal
Regards.
Ken.
post #3 of 15 (permalink) Old 04-03-2010, 04:55 PM Thread Starter
First Name: Ken
Thank Bj,I'll give it atry.
distrbd is offline
post #4 of 15 (permalink) Old 04-03-2010, 06:34 PM Thread Starter
First Name: Ken
I just looked at it throughly and there's no way you can remove those springs with out dismantling the router,at least partially(motor housing,side covers,handles etc.)
distrbd is offline
post #5 of 15 (permalink) Old 04-03-2010, 07:55 PM
Hi Ken
Remove the black base plate from the router and take a real hard look at the tubes,some have snap rings and some use roll pins to hold the tubes in place..the springs will be in the tubes..
post #6 of 15 (permalink) Old 04-03-2010, 08:15 PM
I dunno guys, here's a link to the parts explode:
Porter Cable 7529 Parts List and Diagram - Type 2 : eReplacementParts.com
Looks to me like the sub-base AND the base need to be removed. Then you may be able to get to the retainers.. buncha parts in there.
John Schaben
jschaben is offline
post #7 of 15 (permalink) Old 04-03-2010, 08:17 PM
BigJimAK's Avatar
It's definitely worth the effort, Ken... I have the PC7518.... one heckuva workhorse. I was spinning a 3-1/2" diameter raised panel bit with the vairable speed set to minumum (10K rpm) with back cutter in it last night and it didn't blink an eye. Sure made one heckuva lot of wood chips though!
Note to self: Use *extra* care and downward pressure with back-cutter bits to ensure the workpiece doesn't ride up in the * tiniest* or you get firewood. Don't ask yourself how you know this!
BigJimAK is offline
post #8 of 15 (permalink) Old 04-03-2010, 08:18 PM
kp91's Avatar
First Name: Doug
Router Raizer
the router raizer may be the best solution.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 15 (permalink) Old 04-06-2010, 07:53 PM
levon's Avatar
First Name: levon
Default hi Ken,
i have that router and had it as my first router in my table.
i agree with you on both your thoughts.
first, it is a heavy clunker and aggravating to use handheld, secondly it was a pain to adjust.
after a lengthy inquiry, i was told you couldnt take the springs out, i presume they meant easily.
it was and is a good router, but the newer lighter routers with built in height adjustments to me make it a bit primitive.
p.s. you can get a nice router with built in height adjustment for a lot less than most router lifts and you have an extra router.
levon
levon is offline
post #10 of 15 (permalink) Old 04-07-2010, 07:18 PM Thread Starter
First Name: Ken
Originally Posted by levon View Post
i have that router and..
I contacted a few members of another woodworking forum and the consensus is that you should leave the springs in when mounting it in a router table ,tape the ON switch tightly in on position and you are good to go ,that's what I'm planing to do plus I need a plunge router for hand held use and this PC 7529 is going to be the one I would use both hand held and table mounted.
Regards.
ken.
distrbd is offline
Wanted: looking to buy porter cable 7518 router asrubin Woodworking Classifieds 12 05-02-2016 09:17 AM
Problem with Porter Cable 892 router the_nite_owl Tools and Woodworking 6 03-06-2011 09:31 PM
porter cable 7518 router cheapest I have seen toolman677 The Bargain Bin 1 09-23-2006 02:54 PM
