Routing a narrow wood piece - Router Forums
post #1 of 6 (permalink) Old 04-08-2010, 12:10 PM Thread Starter
Joescroller's Avatar
First Name: Joe
Default Routing a narrow wood piece
Excuse my ignorance but , how does one rout a piece of wood that is narrower than the fence opening on a table mounted router...thanks for your consideration.
Joe
Joescroller is offline
post #2 of 6 (permalink) Old 04-08-2010, 12:29 PM
kp91's Avatar
First Name: Doug
Joe,
Hopefully you rout the edge while it is still attached to a larger board. If you could post a picture or a sketch of what you're trying to do, that would be helpful. (you may have to make a couple of extra posts before it will let you attach a picture)
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 6 (permalink) Old 04-08-2010, 01:45 PM
Joe
Hi Joe - Welcome to the forum
Not sure that the 10 post rule applies to pics. I think it is just for links.
Without knowing exactly what you are trying to accomplish my first thought was for a zero clearance fence. Depending on the length of the workpiece (I'm thinking you are doing the endgrain on a narrow piece of stock) a large push block or coping sled would probably work.
If it is just a small piece overall, a small parts jig would be in order.
Really need a bit more of a description to get to a definitive response.
John Schaben
jschaben is offline
post #4 of 6 (permalink) Old 04-08-2010, 02:24 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Joe
Following on from John's response, either of the following could be a solution.
Cheers
Peter
Name:	Coping Sled reduced top786.jpg
Name:	Coping Sled reduced RHS top787.jpg
Name:	Coping Sled reduced Base 788.jpg
Name:	Coping Sled reduced Front 789.jpg
istracpsboss is offline
post #5 of 6 (permalink) Old 04-08-2010, 02:39 PM
Country: Croatia
First Name: Peter
Cheers
Peter
I should have added this one.
Cheers
Peter
post #6 of 6 (permalink) Old 04-08-2010, 05:55 PM Thread Starter
First Name: Joe
Default Thanks !
Okay, that's the answer, a zero clearance fence. Exactly what I need to rout a narrow end of a piece of wood. Thanks so much for each reply and the great details picts too!!
Joe
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
Newbie - about to do first big routing project PhillyGuy General Routing 44 04-14-2009 06:22 PM
Hello all GoonMan New Member Introductions 9 03-26-2005 06:54 AM
Advanced (?) Template Routing billdcon Jigs and Fixtures 6 03-09-2005 12:07 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
