Dust extraction - Router Forums
post #1 of 10 (permalink) Old 10-29-2010, 08:06 AM Thread Starter
Country: Sierra Leone
First Name: Roger
Default Dust extraction
Hi guys/gals
I have a Trend T11 Router that is mounted under a Kreg router table most of the time. The bottom (nearest the collet) bearing has packed up in less than 12 months. Any ideas how to extract the dust/chippings from under the table, to prevent them from entering the motor.
I work in West Africa, so buying "off the shelf" items is very difficult. I have been trying to think of a custom made vacuum head. I have a proper router vacuum, which is hooked up to the table fence.
Cheers for now
Roger
Roger B M is offline
post #2 of 10 (permalink) Old 10-29-2010, 10:08 AM
Ralph Barker's Avatar
First Name: Ralph
Default one approach
One approach is to build an enclosure, with a dust extraction port. around the router below the table, and then attach another vacuum (assuming you don't have a large dust collection system). Part of the trick is to balance the volume of air intake (holes, etc.) to the suction of the vacuum, so you get good flow.
- Ralph
Ralph Barker is offline
post #3 of 10 (permalink) Old 10-29-2010, 10:25 AM
Hi Roger
The trick is to get it right at the point where the dust comes into the cabinet, many routers come with a pickup tube,use it on the router in the cabinet ,,,,
if yours didn't come with one just make one with some Hvy.wall PVC pipe,cut a hole in the PVC tubing to fit your vac.hose, it will suck up all the dust for you..
post #4 of 10 (permalink) Old 10-29-2010, 06:09 PM
Hi Roger,
Welcome to the forum
Sydney, Australia
jw2170 is online now
post #5 of 10 (permalink) Old 10-31-2010, 07:04 PM
xplorx4's Avatar
First Name: Jerry
Greetings Roger and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #6 of 10 (permalink) Old 10-31-2010, 08:01 PM
allthunbs's Avatar
First Name: Ron
Originally Posted by Roger B M View Post
Hi guys/gals
Cheers for now
Roger
Hi Roger:
There is a thread on one of the forums specifically for options for dust collection:
http://www.routerforums.com/shop-saf...tml#post186623
There includes dust collection that is store-bought or home made and some are well researched too. Well worth your taking a detailed look.
Glad to have someone from Sierra Leone.
Allthunbs
allthunbs is offline
post #7 of 10 (permalink) Old 05-25-2011, 07:27 AM
First Name: Dave
Hi guys/gals
Cheers for now
Roger
Hello Roger
Have just joined Router forums as I've just bought a T11 and the 1st thing I read
is your issue with a blown bearing.
Hope you resolved the problem.
I will be getting a Woodrat as i prefer cutting tools to be above the work so I can see what is going on (ex toolmaker).
My thought on having traditional table are why have dust and cuttings falling onto the router housing and damaging the motor - also a possible safety hazzard with fire?
Anyway I'm rambling again hope you sorted out the issue and perhaps you should crate a new post as to what you did.
regards
Craywater is offline
post #8 of 10 (permalink) Old 05-25-2011, 11:01 AM
crazycol's Avatar
First Name: colin
hello roger, and welcome to you.
also welcome to you too dave.
parachute for sale one red stain
crazycol is offline
post #9 of 10 (permalink) Old 05-25-2011, 11:12 AM
papawd's Avatar
First Name: warren
Welcome, I hope all works well with dust collection. Good luck finding what You need in Your area of the world...
papawd is offline
post #10 of 10 (permalink) Old 05-25-2011, 02:37 PM
One advantage of having a plate mounted router is the fact you can lift it out of the table easily and blow out the dust and swarf with low pressure compressed air. Doing this on a regular basis is the best solution I have found. I will soon be posting a "sticky thread" which will show at the top of the table mounted routing section on a new table build. One of the features will be under the table dust collection you can easily build; this will adapt to most router tables.
Dust extraction Qs. BIGjiLm General Routing 11 08-23-2010 04:51 AM
Dust Extraction - Where to start? kingnerk Shop Safety 22 01-08-2010 11:37 AM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
Fence Mounted Dust Extraction Mike Wingate Table-mounted Routing 12 07-27-2009 10:43 AM
Found: Wanted Bosch RA1173 Dust Extraction Hood -Sam- Woodworking Classifieds 10 11-01-2005 10:43 PM
