Please help me find..... - Router Forums
post #1 of 27 (permalink) Old 11-03-2010, 11:30 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Please help me find.....
...a switch that will turn on my DC when the table router or TS is started.
Appreciate any help finding this item. I don't know what to call it to search for it.
Don't want the Long Ranger. Don't need another remote to clutter the shop and get lost.
EDIT, I found it!
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 27 (permalink) Old 11-03-2010, 12:13 PM
Hi Gene
It comes on some vac.like the one below, I think Rockler has them but they don't list it on the net so a call is needed I think.
Dust Collectors and Dust Collector Accessories
It's funny you ask about it, my son was over last weekend and I ask him to make me one, but it turns off and on by the sounds of the router .
use Auto alarm type device box.. I now use one with the hand buttons but it would be nice if it was auto... lazy old fart I am..
EDIT, I found it!
post #3 of 27 (permalink) Old 11-03-2010, 12:52 PM
EDIT, I found it!
Ok Gene, I give up. What did you find and where
Bj - I looked at that vac - I'm not sure it'll work with a table saw or router, at least not very long. It specificies to use with palm sander or something so I suspect that the vacuum + table saw or router gonna be a lot bigger than the breaker. Dam marketing types - gotta read the description real close and then figure out what it said.
John Schaben
jschaben is offline
post #4 of 27 (permalink) Old 11-03-2010, 01:15 PM
Hi John
For 400.oo bucks it should pop the tab on the beer and bring one over at the same time..
post #5 of 27 (permalink) Old 11-03-2010, 01:36 PM
First Name: Ron
There are several and more than two are listed on Amazon.com. They run around $40 to $60. One runs both the tool and dust collection off the same circuit, the other, I forget the brand and is on my Christmas list, has two plugs that can be run off two separate lines. When the tool is switched on, the DC is turned on as well.
The ratings are pretty good on both.
rweerstra is offline
post #6 of 27 (permalink) Old 11-03-2010, 01:42 PM
First Name: Ron
Try Rockler I-socket tool and vacuum switch, part number 20890, for $36.99. Also there is iVac Automated Vacuum Switch for a little more and both are on Amazon.com.
post #7 of 27 (permalink) Old 11-03-2010, 01:50 PM
Thanks Ron
i-socket 110m Tool and Vacuum Switch - Rockler Woodworking Tools
post #8 of 27 (permalink) Old 11-03-2010, 02:49 PM
Hi John
Should keep it cold too
I dunno, that i-socket looks like it has the same itch.... runs both off the same circuit. Maybe I'm just a bit paranoid because I'm stretched on electrical capacity so I may be a bit oversensitive. My 11 amp vac and 15 amp table saw don't fit on the same circuit. Matter-of-fact, I run them on seperate phases.
John Schaben
jschaben is offline
post #9 of 27 (permalink) Old 11-03-2010, 03:08 PM
Guest
First Name: Regis
Gene,
If your DC is 1.5 hp or more the iVac will not work so I hope you didn't choose that solution. It works fine with shop vacs but the starting load of larger DC exceeds the 12 amp breaker on the vacuum circuit. The tool ciruit is also limited to 12 amp but the advertizing literature is not just misleading, it's dead wrong!
Regis
48394 is offline
post #10 of 27 (permalink) Old 11-03-2010, 04:01 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Here is the one I found. Note it has a delay. Dust Collection - iVac Automatic Tool Switch
Gene Howe
Snowflake, AZ
Where is my "statistics" - Where I find a link to all my posts? sofasurfer Site Help and Suggestions 10 02-15-2010 11:26 AM
Can't find mrbillsfan311 Table-mounted Routing 4 01-04-2010 10:00 AM
can't find rounding hand tool frankjay02 Tools and Woodworking 3 10-15-2009 10:43 AM
How do I find.... sher622 New Member Introductions 2 04-01-2009 03:27 AM
can't find lonewolf New Member Introductions 2 03-28-2006 11:52 PM
