Question on small part routing - Router Forums
post #1 of 8 (permalink) Old 11-05-2010, 09:02 AM Thread Starter
First Name: Ron
Default Question on small part routing
I have about 50 disks, 1-1/4 inches in diameter, 1/4 inch thick which are game pieces. I would like to round the edges on both circumferences with a 1/8 inch rounding bit with a bearing. I don't know if that can safely be done on a table by hand since there are no holes in the disks to anchor them. I will be making them from slicing a dowel rod that I have not purchased yet, but I suspect the dowel will be oak.
I have done this on larger wheels for toys but nothing that small.
Any suggestions to accomplish this safely?
rweerstra is offline
post #2 of 8 (permalink) Old 11-05-2010, 09:21 AM
Ralph Barker's Avatar
First Name: Ralph
Do you have a lathe? If so, my suggestion would be to turn a series of beads on the dowel first, and then slice them free into the little disks you want. Trying to rout a round-over on that small of a piece seems way to dangerous to me.
- Ralph
Ralph Barker is offline
post #3 of 8 (permalink) Old 11-05-2010, 09:22 AM
HI Ron
I would suggest using a SMALL router table and your Dremel tool with the Small router bits (round over) you can turn the speed way down and that should take the fear out of it...a quick made jig to run the disk in should do the trick..and to keep your fingers out of the router bit..
Amazon.com: Dremel 231 Shaper/Router Table: Home Improvement: Reviews, Prices & more
Amazon.com: Milescraft 1098 Rotary Tool Work Center Router Table: Home Improvement
Amazon.com: dremel router bits set Home Improvement
Name:	disk fence.jpg
post #4 of 8 (permalink) Old 11-05-2010, 10:26 AM
Hi Ron - How about combining Bj's and Ralph's suggestions. Use a bit like this:
MLCS groove forming router bits
on your router table to create the series of grooves in the rod and then cut them apart.
For a jig, I would just use a v-block from the front of the table to the bit and use the fence for a stop block. Drop the rod on the bit, give a quick rotation and cut off your disk.
John Schaben
jschaben is offline
post #5 of 8 (permalink) Old 11-05-2010, 10:35 AM Thread Starter
First Name: Ron
Thanks for the suggestions. You have been helpful.
post #6 of 8 (permalink) Old 11-05-2010, 11:51 AM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi all
You can make little circle with this tool (it is in english)
http://www.lescopeaux.asso.fr/Techni...de_Anglais.pdf
Cheers
Daniel
Member of the french site for woodworkers
Santé is offline
post #7 of 8 (permalink) Old 11-05-2010, 01:18 PM
HI Ron
Think biscuits
Just buy some disks that are done ,,I'm not sure if you can use the one below they are 1 1/2" OD and 5/32" thick but if you put some water on them they will blow up to 3/16" thick and with just a little bit of sanding your done..and you can get them for peanuts.
Biscuit kits and Glue Spreader
To cut out small cir. use a plunge router over bit to do the job all with one bit..you can make your own jig easy.
http://www.youtube.com/watch?v=18CUKZo2JUE
http://www.routerforums.com/attachme...r-100_1939.jpg
Or
http://www.amazon.com/Trend-PFJ-SET-...8987584&sr=1-1
post #8 of 8 (permalink) Old 11-05-2010, 01:31 PM Thread Starter
First Name: Ron
It never ceases to amaze me that there are always so many ways to accomplish the same task. Thanks for all the wisdom.
Table Routing vs Shaper with collets woodnthings Table-mounted Routing 11 06-23-2009 01:31 AM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
Routing bracket edges dmonson General Routing 5 10-06-2008 10:46 PM
A small case. Is this to be the 1st. one ? Benny LaBaw Show N' Tell 24 07-19-2008 12:43 AM
