RT mounting plate...advice please! - Router Forums
post #1 of 2 (permalink) Old 11-10-2010, 04:34 AM Thread Starter
matt1710's Avatar
Country: New Zealand
First Name: Matthew
Default RT mounting plate...advice please!
Hi
Am about to order a mounting plate for my soon to be constructed RT, and would like some advice on which one might suit my needs best. Initially at least, I'll be using it with a Makita 3612C. I'm new to routing, but prefer to invest in quality equipment that will last and that I can grow into - rather than starting at the bottom and needing to replace it soon after. I'm not going for the high-end of the mounting plates, and would prefer to stay under the US$50 mark.
I've looked at the Rosseau plate which seems to get good reviews - although the 'crown' on it seems unpopular. I've also heard that the rings are a pain to remove. There's also one from MLCS. At this price point, they all seem to be phenolic rather than metal - which I guess is fine.
Ultimately I'd like a plate that doesn't need to be drilled by me, to accept the 3612C. It should be strong enough to support my "tank router" - and having a freehand guide pin will probably prove useful.
Any advice - particularly from 3612C users - would be much appreciated!
Regards
Matthew
matt1710 is offline
post #2 of 2 (permalink) Old 11-10-2010, 07:13 AM
Country: Philippines
First Name: Jarod
Since the Makita 3612Cs are quite heavy, Aluminum would be the best way to go. Incra, WoodPeckers, Pinnacle, etc would have good options for you. Otherwise, you could ask a machine shop to fabricate you a custom one, as you need to stretch your $50 a bit more to get a good insert.
j4r0d is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Q: mounting plate advice duncsuss Table-mounted Routing 6 09-04-2010 07:22 PM
Mounting Router Base to Table Plate ccmnova Table-mounted Routing 5 12-02-2009 07:10 PM
Old Rockler aluminum mounting plate inserts Mike Table-mounted Routing 0 07-07-2009 09:57 PM
