Bit Raising - Router Forums
post #1 of 6 (permalink) Old 11-24-2010, 11:15 AM Thread Starter
Zurt's Avatar
First Name: Burt
Default Bit Raising
I'm not clear on the concept of adjusting and changing bits on a table.
  1. On a seamless table adjustments are made by loosening the motor. Bit changes require removal of the motor.
  2. On a base plate, the adjustment is made similar to #1 but the bit change is made by removing the base plate with the unit attached.
  3. On a lift, everything is done via crank (yes/no?)
  4. On routers with "cranks," adjustments and bit changes are done in place regardless of seamless or base plate (yes/no?)
  5. Would a Router Raizer solve all these problems on my Bosch 1617?
It would seem to me that it would be more economical to buy a router with a crank then buying a lift. If this is so, then why buy a lift at all? What am I missing?
Zurt is offline
post #2 of 6 (permalink) Old 11-24-2010, 11:40 AM
Hi Burt - I haven't got a lift but will try to help. In the first place, built in "above table adjustments" are a fairly recent development and not all routers are so equipped. Also, even when they are many times access to the adjustments end up being covered by the fence. A lift will resolve that issue.
John Schaben
jschaben is offline
post #3 of 6 (permalink) Old 11-24-2010, 11:50 AM
Ralph Barker's Avatar
First Name: Ralph
There's no universal solution that works for everyone in all situations.
It appears that there is a Router Raizer that is designed to work with your Bosch 1617. So, that would be one solution - assuming you are OK with the router mod that appears necessary for that lift, and are willing to (more or less) dedicate the plunge base to the table.
Would a cranky router be more economical? Only if you don't already have a non-cranky one.
- Ralph
Ralph Barker is offline
post #4 of 6 (permalink) Old 11-24-2010, 12:21 PM
Hi
Just my 2 cents
For the price of some of the lifts you are better off just buying a new router that has one built in..most of the lifts are in the 250.oo + range, without a motor ,it's common sense thing..
You can't have to many routers ..
post #5 of 6 (permalink) Old 11-24-2010, 12:25 PM Thread Starter
Zurt's Avatar
First Name: Burt
Do the crank style routers allow for bit changes while on the table? If so, any recommendations?
Zurt is offline
post #6 of 6 (permalink) Old 11-24-2010, 12:49 PM
HI
Many do but you can use a offset wrench to do the job if they don't go all the way.
Heavyweight and Precision Router Table
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Bit Broke: Bad bit or bad technique Spokaneman Table-mounted Routing 14 01-26-2009 04:57 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
