Ryobi RE1200 Router spring removal - Router Forums
post #1 of 12 (permalink) Old 12-07-2010, 10:58 PM Thread Starter
bikeless's Avatar
Country: South Africa
First Name: Gary
Default Ryobi RE1200 Router spring removal
Hi All,
I have a Ryobi RE1200 Plunge router mounted to a Ryobi Router Table.
Does anyone here know how to remove the springs from the router.
The router works well with the table except the springs make height adjustments a pain.I want to remove th springs and make my own height adjusting mechanism for it.
I tried removing the two allen(hex) key bolts in the base but I cant budge them.
any info or advice would be greatly appreciated
Model: RE1200
Electronic speed control
6,35/8mm collect capacity
bikeless is offline
post #2 of 12 (permalink) Old 12-14-2010, 04:17 AM Thread Starter
bikeless's Avatar
First Name: Gary
mmm, seems that removing the Allen(hex) screws at the bottom of the base is the only way.
I might drill them out, but then im going to have to re-tap to fasten the base on.....
bikeless is offline
post #3 of 12 (permalink) Old 12-14-2010, 04:36 AM Thread Starter
bikeless's Avatar
First Name: Gary
after some more more googling I have found a router that looks identical to the ryobi re1200 but its called a GMC R1200 1/2" Router.
strange.
bikeless is offline
post #4 of 12 (permalink) Old 12-14-2010, 06:16 AM
this may help
Router Workshop: Spring Removal
post #5 of 12 (permalink) Old 12-14-2010, 10:00 AM Thread Starter
bikeless's Avatar
First Name: Gary
I managed to get them out eventually(after stripping the entire router to pieces).
If anyone is intrested in a how to, i will do once i can post images.
bikeless is offline
post #6 of 12 (permalink) Old 12-14-2010, 02:29 PM
Hi Gary - That would probably an appreciated addition to the "Router Reference>Ryobi" section.
John Schaben
jschaben is offline
post #7 of 12 (permalink) Old 07-09-2012, 02:49 AM
First Name: Nick
Default How did you get it right?
Hi,
I tried, got the hex screws out, but nothing after that. Can you tell me how you managed it?
Thanks,
Nick
nrwiersma is offline
post #8 of 12 (permalink) Old 07-09-2012, 07:30 AM
welcome to the forum, Nick.
Gary has not been back for 18 mths, but there is a chance someone else may be able to help you.
Sydney, Australia
jw2170 is offline
post #9 of 12 (permalink) Old 07-16-2012, 02:39 AM Thread Starter
bikeless's Avatar
First Name: Gary
Originally Posted by nrwiersma View Post
Hi,
Thanks,
Nick
Hi Nick,
You cant remove the springs from the bottom"base".I removed the top plastic housing of the router and removed the springs from the top.it was quite a job but well worth it.
As mentioned i have not been around for a while but as circumstances have changed i am slowly getting back into my woodworking.
I will try get you some photos for tomorrow.
Cheers
Gary
bikeless is offline
post #10 of 12 (permalink) Old 07-16-2012, 11:54 AM Thread Starter
bikeless's Avatar
First Name: Gary
ok, this wont be the best ever description and images, but it will get you on your way im sure.
image1 - the 1200 ryobi plunge router.
image 2 - Remove the four Screws that hold down the top cover and pry the top cover off.
imjage 3 - Remove the four Plastic "thingies" with a flat screwdriver.Under neath them are four screws which you need to loosen and Cut the Brown Wire "Yes Cut it"
image 4 - here you can see one of the screws that was hidden by the plastic "thingies"
image 5 - you can now lift up the entire casing and remove the springs.
If memory servers when you cut the Brown wire, you also eed to disconnect all wiring as well - push lugs, so you can life the cover enough to get the springs out.
Hope this helps.
any questions send me a pm.
cheers
Gary
bikeless is offline
Ryobi ERT-1150V router trevor Portable Routing 4 06-15-2009 12:50 PM
Mounting a Ryobi R175 Plunge Router bobtheengineer Table-mounted Routing 6 01-14-2009 01:34 AM
Removal of router springs for table use pianoman8 The Voting Booth 20 11-08-2007 03:58 PM
