Routing outside edge of a circle - Router Forums
post #1 of 2 (permalink) Old 12-09-2010, 11:56 PM Thread Starter
First Name: Barry
Default Routing outside edge of a circle
I am very new so if I am in the wrong forum, please direct me to the proper place. Routing a straight piece of inch acrylic using a beading bit seems to be straight forward enough when using a table and a guide. What I would like to do is put this rounded edge on a piece of inch acrylic that is 8 inches in diameter. What advice can people offer me so that I do not mess up while routing the outside edge of an 8 inch acrylic disc?
barryaclarke is offline
post #2 of 2 (permalink) Old 12-10-2010, 08:34 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The first shot shows how I routed a true edge on Acrylic. The second one shows a fancy edge on a partly made clock which does not require a template because it is already round, and any shape of bearing cutter can be used but it's important that either a starting pin or better still, the fence be used to feed the disc into the cutter and the disc must be rotated in an anti-clockwise direction.
Harry
harrysin is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
routing a previously routed edge Fishbaydoc Router Bits - Types and Usage 7 08-31-2009 11:40 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
Routing a decorative edge on the inside of a faceframe? Woodworker 52 Portable Routing 2 01-29-2008 01:00 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
