Split Fence - Question - Router Forums
post #1 of 5 (permalink) Old 12-13-2010, 07:46 AM Thread Starter
First Name: Phil
Default Split Fence - Question
Hi,
I have a fixed fence on my table now and want to add a split fence to it. I was thinking of 1/2 inch mdf. Do you think this would be ok. The main fence is 3/4 inch mdf.
thanks,
Phillym is offline
post #2 of 5 (permalink) Old 12-13-2010, 07:58 AM
Guest
First Name: Regis
Phil,
I'd suggest 3/4" in case you want to add 3/8" grooves for featherboards later.
Regis
48394 is offline
post #3 of 5 (permalink) Old 12-13-2010, 09:27 AM
Country: Germany
First Name: Titus
I'd also go with the 3/4".
Titus A Duxass is offline
post #4 of 5 (permalink) Old 12-13-2010, 10:51 AM
Ralph Barker's Avatar
First Name: Ralph
Another vote for 3/4". As mentioned, that gives you enough thickness to rout T-slots for accessories like feather boards, stop blocks, etc.
- Ralph
Ralph Barker is offline
post #5 of 5 (permalink) Old 12-13-2010, 11:35 AM
Hi Phil
Yes it will work but I would suggest a tee slot on the top edge ,so you can hang items on the fence( stop blocks,etc.), a key hole bit works well for the tee slot and a hex bolt will just slide in the slot just right
The real neat part of the split fence you can turn it into planer fence,with a insert of formica behind the out feed end of the 1/2" thick MDF stock fence,that you can use for the lock miter bit,trim bit.etc. just about any router bit without a bearing on it or with some bits that have a bearing on them and not use the bearing on the bit almost all the bits that come with the bearing in place can be removed to get a cutter with a diff.profile look..
Here's a snapshot of my 1/2" thick MDF sub.fence,see below
Key Hole Cutting Router Bits
#5438 3/8" 1/4" 1/4" $8.00
http://www.mlcswoodworking.com/shops.../bt_keyhl.html
Originally Posted by Phillym View Post
Hi,
thanks,
Split Fence - Set Up Tips Titus A Duxass Table-mounted Routing 32 09-13-2010 04:05 AM
Table Fence Question Bob N Table-mounted Routing 15 11-19-2009 05:33 AM
Introduction & 1st question (table saw router fence recs) david coburn Tools and Woodworking 4 05-27-2009 09:05 AM
