HELP! Messed up my router plate - Router Forums
post #1 of 7 (permalink) Old 12-16-2010, 01:08 PM Thread Starter
Zurt's Avatar
First Name: Burt
Default HELP! Messed up my router plate
I took the "Do not remove" label from my HF router plate. Left a big blog of glue so I first tried mineral spirits. Didn't do a thing so I upped the ante with Acetone. That made a big ugly mess and there is still glue on the surface. I was able to scrape enough of the glob to see that the plate did not melt, which was my biggest fear.
Is there an easier way of cleaning the plate besides scraping with a razor blade?
I'm hoping to get a workable table before the end of 2025 if I live that long.
Thanks,
Burt
Zurt is offline
post #2 of 7 (permalink) Old 12-16-2010, 01:48 PM
bobbotron's Avatar
First Name: Rob
So the acetone didn't melt the plastic at all?
I usually use the product "Goo gone" for sticker removal, works pretty well. Some times it takes two or three applications - for heavy gunk, first time you get most of it off, the second time pretty much everything, the third time you've got a clean surface.
bobbotron is offline
post #3 of 7 (permalink) Old 12-16-2010, 01:50 PM Thread Starter
Zurt's Avatar
First Name: Burt
I gave it another bath in mineral spirits and this time it worked. The few bits of stubborn glue came off with my thumb nail. All is good. Fortunately, the acetone did not melt the plate. Perhaps, kudos to HF for quality?
Burt
Zurt is offline
post #4 of 7 (permalink) Old 12-16-2010, 01:54 PM
Goo Gone, works well also router bit cleaner..
Thanks,
Burt
post #5 of 7 (permalink) Old 12-16-2010, 09:58 PM
BrianS's Avatar
First Name: Brian
Glad you got it cleaned up with no damage. I've used a blow dryer to heat the sticker, softening up the adhesive. Followed with goo gone, as others have recommended.
Brian
(Origin uncertain)
BrianS is offline
post #6 of 7 (permalink) Old 12-16-2010, 10:07 PM
Danger ,Danger, Will Robson putting any heat to the plate, you don't want to end up with a wash board
post #7 of 7 (permalink) Old 12-17-2010, 07:48 AM
First Name: Danny
WD40 will remove the lable glue.
jd99 is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Bench Dog 40-001 Router Table and options for Router Plate. guht Table-mounted Routing 9 07-08-2010 01:53 PM
Router plate as base plate?? xplorx4 General Routing 6 05-24-2009 06:19 PM
