HF Plate Magnets - Router Forums
post #1 of 3 (permalink) Old 12-18-2010, 05:01 PM Thread Starter
Zurt's Avatar
First Name: Burt
Default HF Plate Magnets
Finally have what appears to be a router table top with base plate. I used the instruction requiring the Rousseau template and everything went together easey-peasy.
However, the top is melamine over particle board. When I drilled the holes for the magnets (5/16" brad point) the holes ended up loose so when I lit the plate out the magnets come along. Should I glue them in or are there other tricks?
Thanks,
Burt
Zurt is offline
post #2 of 3 (permalink) Old 12-18-2010, 06:04 PM
Cassandra's Avatar
First Name: Cassandra
Hi Burt:
What I did was to use rare earth magnets with center holes in them. I them put a screw through the hole into a hardwood dowel that was glued into the table top. The screw holds the magnet down, hold the MagnaLock ring up, and allows leveling the ring.
Personally, I would not glue the magnet in, just in case you need to replace the magnet at a later date.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #3 of 3 (permalink) Old 12-18-2010, 08:01 PM
Hi Burt
Here's a small tip,use some plastic wrap,slip it over the hole than put the magnet in place and then use a c-clamp and a small block of wood to press it into the hole.
The plastic wrap will let it slide in nice and easy but will fill the gap.. use a BIC light to clean up the plastic wrap from the over hang..
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Do I need a router plate for my new table? Ryan's Dad Table-mounted Routing 16 09-16-2011 06:53 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
