What is plastic laminate? - Router Forums
post #1 of 26 (permalink) Old 12-24-2010, 02:35 PM Thread Starter
Zurt's Avatar
First Name: Burt
Default What is plastic laminate?
I went to Home Depot to buy plastic laminate. No one seemed to know what this is. Finally, someone walked me over to their plastics section. What they had there was acrylic sheets in various sizes. The 24"x48" sheet was over $20 and all the sheets were pretty funky - scratches and torn edges.
Is this what I'm to put on top of MDF?
Thanks,
Burt
Zurt is offline
post #2 of 26 (permalink) Old 12-24-2010, 03:45 PM
Cassandra's Avatar
First Name: Cassandra
Hi Burt:
Laminate is a layered structure of resin and paper, bonded under pressure. One trade name is Formica. It is not acrylic sheet.
In HD I usually see the aisle where they keep the 4x8' sheets of various products, such as 1/4" and 1/2" hardboard, plus counter-top material (laminate, that is).
In the Lowes I shop at, they keep the laminate in the section with pre-fab counter-tops.
Cassandra
Cassandra is offline
post #3 of 26 (permalink) Old 12-24-2010, 03:47 PM
BigJimAK's Avatar
Burt,
Think Formica (one brand).. kitchen countertop laminate for custom-shaped countertops. It lets the wood slide smoothly over the table without catching. In the big box store here its against the back wall of the store behind the kitchen area. Here its sold in 48"x96" sheets for about ?$50? per sheet. Shipping to Alaska is high so hopefully the price I"ve given is high for your area.
BigJimAK is offline
post #4 of 26 (permalink) Old 12-24-2010, 04:12 PM
Hi Burt,
In Australia, two brand names are Formica and Laminex.
You might try those as a starter.
Actually, Formica is owned by the Laminex Group...
Sydney, Australia
jw2170 is offline
post #5 of 26 (permalink) Old 12-24-2010, 04:12 PM
Jack Wilson's Avatar
First Name: Jack
Burt, another great name in the laminates department would be Wilsonart, of course there are also Nevanar and Pionite.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #6 of 26 (permalink) Old 12-24-2010, 05:28 PM Thread Starter
Zurt's Avatar
First Name: Burt
Are the sheets only available in 4'x8'? I have enough problems cutting mdf and ply sheets tho I usually get HD to cut them for me. Think they would cut the formica?
Thanks for the replies,
Burt
Zurt is offline
post #7 of 26 (permalink) Old 12-24-2010, 07:05 PM
BigJimAK's Avatar
They sure should, Burt.. I cut mine on my table saw...
BigJimAK is offline
post #8 of 26 (permalink) Old 12-24-2010, 09:11 PM
Cassandra's Avatar
Burt
Burt:
HD has a cutting department in each store (at least in Canada.) They should have no problem making cuts for you.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
post #9 of 26 (permalink) Old 12-24-2010, 11:08 PM
Ralph Barker's Avatar
First Name: Ralph
The HD and Lowes stores here in NM also will cut sheets for you. They might also have offcuts from other customers, so ask if they do and have a piece slightly larger than what you need.
I'm surprised that the HD clerk wouldn't know that "laminate" is the generic name for products like Formica. That sort of thing is why I prefer shopping at Lowes.
- Ralph
Ralph Barker is offline
post #10 of 26 (permalink) Old 12-24-2010, 11:16 PM
boogalee's Avatar
First Name: Al
You could also use melanine from Home Depot.
Search Results for melamine
boogalee is online now
Plastic Laminate Stevenlgts Table-mounted Routing 2 12-27-2009 11:29 AM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
Plastic laminate S Bolton Table-mounted Routing 12 03-16-2008 06:40 PM
glue for plastic laminate S Bolton Table-mounted Routing 8 09-29-2007 12:05 PM
