Hmmmh? - Router Forums
post #1 of 30 (permalink) Old 12-27-2010, 04:26 AM Thread Starter
Country: Germany
First Name: Titus
Default Hmmmh?
In the style of a certain Mr. R Harris - Can you guess what it is yet?
Titus A Duxass is offline
post #2 of 30 (permalink) Old 12-27-2010, 05:15 AM
Phil P's Avatar
First Name: Phil
Is it a router table?
Phil P is offline
post #3 of 30 (permalink) Old 12-27-2010, 06:32 AM
dutchman 46's Avatar
First Name: Howard
A router table and a base plate. without the finish veneer
John 3:16
dutchman 46 is offline
post #4 of 30 (permalink) Old 12-27-2010, 07:02 AM Thread Starter
Country: Germany
First Name: Titus
Correct. It's going to be my OP clone.
I need a RT than can be stored.
"without the finish veneer" - unfortunately I can't get finished ply or formica sheeting to finish it.
I will be coating the top in epoxy resin which will give a hard slippy surface.
post #5 of 30 (permalink) Old 12-27-2010, 07:13 AM
allthunbs's Avatar
First Name: Ron
Hi Titus:
Comment: your idea of epoxy is excellent but my experience is that I could never get it on evenly. I always had to grind it down after. If you can, thin a lot so it goes on like a paint, not like a gel or paste.
I might recommend as an alternative "spar varnish." I don't know what you call it there but it is used on wooden sailboats and after multiple very thin coats, comes up like a sheet of glass. You can use something similar on freshly sanded wood floors.
haben ein frohes Weihnachtsfest und ein glückliches neues Jahr (I hope Google didn't screw it up too badly ;-)
Allthunbs
allthunbs is offline
post #6 of 30 (permalink) Old 12-27-2010, 07:32 AM Thread Starter
Country: Germany
First Name: Titus
Danke, gleichfalls!
Google didn't screw it up for me (I'm not German).
The epoxy that I have is very liquid, almost like a good spar varnish, I used it on my canoe build. It is quite easy to apply.
I will probably finish the top in spar varnish as epoxy is UV sensitive and breaks down very quickly in sunlight.
post #7 of 30 (permalink) Old 12-27-2010, 03:27 PM
allthunbs's Avatar
First Name: Ron
Danke, gleichfalls!
Well, at least I tried ;-)
Excellent, thank you. I didn't know I could put spar varnish on top of epoxy finish.
Allthunbs
post #8 of 30 (permalink) Old 12-27-2010, 04:03 PM
First Name: Howard
How well does it hold up to scratches?
John 3:16
post #9 of 30 (permalink) Old 12-28-2010, 02:01 AM Thread Starter
Country: Germany
First Name: Titus
To be honest - not very well but you can easily slap on another coat.
I would rather have a formica (or similar) surface.
I did think about putting on a 1mm thick sheet of stainless but have concerns about bit damage.
post #10 of 30 (permalink) Old 12-28-2010, 05:43 AM
allthunbs's Avatar
First Name: Ron
Hi Howard:
Spar Varnish is similar to the varnish that you use on your wood floors in your house. It can be walked on in a day but the more it cures the more "scratch resistant" it becomes. My wife dragged a chair across the newly finished oak floor (two days old) and scratched the varnish. A month later she did the same thing with no effect. Spar varnish is reported to be tougher than varnish in wet conditions. That's where it gets its name -- from varnishing the spars on wooden sailing ships.
Allthunbs
