fear of runing the work - Router Forums
post #1 of 7 (permalink) Old 01-03-2011, 09:26 AM Thread Starter
First Name: Phil
Default fear of runing the work
Hi,
I have almost completed a Jewelery Box but I would like to round over the lid and box so that it will provide a finger opening. I have never did this before and I am a little skeptical about doing this. I can either try this on the router table or with a compact router. The stock is 1/2 inch so I was thinking of using a 1/4 inch roundover bit on both side to give a complete roundover.
I would appreciate any thoughts or help.
Phillym is offline
post #2 of 7 (permalink) Old 01-03-2011, 10:14 AM
Cassandra's Avatar
First Name: Cassandra
Hi Phil:
First and foremost, do practice runs on scrap stock.
Second, doing a complete round-over using two passes of a 1/2-thickness bit can work, but you should be using a router table with a fence or a coping sled.
It can be tricky doing this by hand routing, especially if one cannot clamp a suitable straight-edge on the workpiece.
Third, personally I would get a half-round bit that would do the complete round-over, not a half round-over.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #3 of 7 (permalink) Old 01-03-2011, 09:37 PM
Ralph Barker's Avatar
First Name: Ralph
I agree with everything Cassandra said, except for the bit. Using a standard roundover and multiple passes gives a little more flexibility, I think. Do practice on scrap stock of similar size, though.
- Ralph
Ralph Barker is offline
post #4 of 7 (permalink) Old 01-03-2011, 11:32 PM
curiousgeorge's Avatar
First Name: George
Originally Posted by Phillym View Post
Hi,
If you want a complete round over use a router table with a 1/2" bull nose bit...
Bull Nose Bit
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #5 of 7 (permalink) Old 01-04-2011, 03:23 AM
gav
Country: Croatia
First Name: Gavin
One thing I've come across when doing this, especially on oak, is that when you get to the the end of the cut you can be at risk of some tear out occurring. I like to use some scrap on the end of the piece I'm working on so the cut ends on the scrap and not on the work piece.
gav is offline
post #6 of 7 (permalink) Old 01-04-2011, 07:31 AM Thread Starter
First Name: Phil
Hi,
Thanks for all the good answers. I will try the different bits on some scrap.
Phillym is offline
post #7 of 7 (permalink) Old 01-04-2011, 07:56 AM
First Name: del
Hi,
do the end grain first than the long run . this will clean up the tair out. I made probly 500 jewelry and trinkit box's. I do the round over on just 3 side's and leve the back juat about 1/8" long than if any tair out on the last cut i can run it thro the table saw and clean it up. I use the router table and fence. I have the RW table. so i can put the fence any where on the table and not relay on the way some tables are set up. I do the cut in one pass and have no problum with mine. a link to my box's most are sold but some aren't.
http://www.craftforum.com/members/de...r-2953/albums/
del schisler
port st. lucie, florida
del schisler is offline
I need some CNC router work done. bobj3 CNC Routing 4 02-28-2019 12:39 PM
My work space! Marc R Show N' Tell 14 06-19-2010 06:54 AM
work in progress: toolchest stef1611 Show N' Tell 10 10-10-2008 01:25 PM
building work stations Glenmore Tools and Woodworking 15 03-23-2005 04:33 AM
