Best bit size for box joints - Router Forums
post #1 of 15 (permalink) Old 01-10-2011, 11:19 AM Thread Starter
First Name: Dean
Default Best bit size for box joints
I've been playing around with a box joint jig that I made that is for 1/4" joints. It works fine on 1/2" stock or less. Also, it gets more difficult to join two pieces when the stock is more than about four inches. So, any thoughts as to a rule of thumb for the best bit size to use in comparison to stock thickness and width?
white66 is offline
post #2 of 15 (permalink) Old 01-10-2011, 11:46 AM
Hi - Welcome to the forum
It sounds more like an error in your jig indexing than a bit size issue. It doesn't take much of an error as it is compounded in each subsequent joint. Let's see, you're making 1/4" joints and it is OK until you get to about 4" or 8 fingers. To me, that's pretty close, a little sanding might fix the jig.
John Schaben
jschaben is offline
post #3 of 15 (permalink) Old 01-10-2011, 05:31 PM Thread Starter
First Name: Dean
Thanks, John. I should add that I'm having more of a problem when using stock that is 3/4". Then I seem to get wavy fingers with the 1/4" bit.
white66 is offline
post #4 of 15 (permalink) Old 01-10-2011, 06:19 PM
HI white66
Here's a little rule I use
1/4" wide box joints,, 1/8" to 3/8" thick stock
3/8" wide box joints,,,3/8" to 3/4" thick stock
1/2" wide box joints...1/2" to 1" thick stock
3/4" wide box loints,,,3/4" to 1 1/2" thick stock
1" wide box joints,,,,1" to 2" thick stock
But on your jig it sounds like the indexing pin is not right the button..if you sand one it will change the fit on the others as well..
The one below will not flex (good for 1/8" to 1/2" thick stock)
1 PC 1/2" SH 5 Slots Adjustable Box Joint Router Bit - eBay (item 140497751832 end time Jan-12-11 17:09:17 PST)
post #5 of 15 (permalink) Old 01-10-2011, 06:24 PM
Ralph Barker's Avatar
First Name: Ralph
Hmmm. That sounds like the 1/4" bit may be working too hard, or something else is flexing. Is this a 1/4" or 1/2" shank bit?
- Ralph
Ralph Barker is offline
post #6 of 15 (permalink) Old 01-10-2011, 09:22 PM Thread Starter
First Name: Dean
1/4" shank. Thought there might be some flex as well so changed to a stronger base plate on the router. Haven't tried it yet, though.
white66 is offline
post #7 of 15 (permalink) Old 01-11-2011, 01:13 PM
Adjusting The Fit
If the fit is too tight, tap the fence towards the bit. If the fit is too loose, tap the fence away from the bit.
ScottR is offline
post #8 of 15 (permalink) Old 01-12-2011, 02:16 PM
LexB's Avatar
First Name: Lex
I've use a 1/4-inch bit for box joints in material as thick as 3/4-inches. I don't cut it full depth in one pass though. I take several passes, each about 1/4-inch deep to reach the full depth. I use an Incra LS fence, so repositioning it is no problem. You could probably do the same thing with a home-built jig too, if it's a snug fit in the miter track.
LexB is offline
post #9 of 15 (permalink) Old 01-13-2011, 01:31 PM
Mike Wingate's Avatar
First Name: mike
Select the bit to match the thickness of the stock. Or 1/4", 3/8" and 1/2" if using the Incra setup.
Mike Wingate is offline
post #10 of 15 (permalink) Old 01-13-2011, 10:54 PM Thread Starter
First Name: Dean
Thanks for all the responses. I made a 1/2" jig and that works much better with 3/4" oak. Still needed to give it a couple whacks with a mallet to get it together, unlike the pine I was used to.
white66 is offline
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
Dove Tail Bit Size Avery Starting Off 0 08-13-2010 08:00 AM
What bit to use for box joints gumball Jigs and Fixtures 10 12-15-2009 12:41 PM
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 12:38 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
