Miter channel or no miter channel? - Router Forums
post #1 of 18 (permalink) Old 01-11-2011, 06:09 PM Thread Starter
30coupe's Avatar
First Name: Russ
Default Miter channel or no miter channel?
Okay, I'm about to build a router table. I like the plans for Norms with the drawer and so forth, but I also looked at one at Woodworking. org that looks pretty nice, although it is way bigger than I would want. Norm's has a miter channel and T-slots for the fence. The Woodworking one has neither. I like the fence system on the latter one, the clamp part anyway, and may go that route. My experience with T-slots on the last table I built was that they tend to fill up with sawdust and become a pain to adjust, so I like the idea of no T-slots.
Now, for my question: should I put in a miter channel or not? I've never had one without, so I don't know if I'd like it or not. I suppose I could build without, then add it later if I thought I had to have it, but I'd kind of like to know the pluses and minuses before I begin.
Let the opinions rain down, guys!
Thanks!
30coupe is offline
post #2 of 18 (permalink) Old 01-11-2011, 06:22 PM
Thanks!
Hi Russ - Welcome to the forum
Like you said, you can always put one in - takin one out?.. maybe not so easy.
John Schaben
jschaben is offline
post #3 of 18 (permalink) Old 01-11-2011, 06:30 PM
xplorx4's Avatar
First Name: Jerry
I have one and use it from time to time, well maybe just a couple times in two year. I will probably put one in again when I re-do my top.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 18 (permalink) Old 01-11-2011, 06:45 PM
Ralph Barker's Avatar
First Name: Ralph
I put a combo miter/T-Track strip in my table, along with T-Tracks in the fence face. I use both horizontal and vertical feather boards often, so they both come in handy.
- Ralph
Ralph Barker is offline
post #5 of 18 (permalink) Old 01-11-2011, 09:57 PM
Gene Howe's Avatar
First Name: Gene
My RT fence is made from extruded aluminum with t track on the top and face as part of the extrusion. Great for feather boards.
As to the table, no t track or miter track. I still use feather boards. I just clamp them to the table.
As far as operations normally aided by a miter gauge (coping, etc) I use sleds that ride against the fence.
With a miter gauge in a track used for coping, the fence must be absolutely parallel to the track. My router fence seldom is and I'm too lazy to make it so each time I cope a frame.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #6 of 18 (permalink) Old 01-11-2011, 10:20 PM
HI
Just a note about the coping sled ,,,it doesn't need to be absolutely parallel to the fence, here's a little trick,,once you zero out the bearing on the bit move the fence back just a little bit say about 1/16" back, the bearing on the bit will keep it just right...many do like to use the coping sled to be safe..with a piece of laminate as a gauge you can just slide the stock up to the fence and lock the stock in place and than just pull it out b/4 making the pass..
I do it all the time with short/small parts ..
post #7 of 18 (permalink) Old 01-11-2011, 11:34 PM Thread Starter
30coupe's Avatar
First Name: Russ
HI
Wow, do I have a lot to learn here. I have no idea what you just said.
I don't have, nor do I know how to use a coping sled. I'm afraid your pictures didn't help me much. Where is your router bit? Does the sled slide against the fence?
I made a box jig similar to the one Steve Maskery made, but due to the crappy surface of my aluminum Craftsman router table. I had to modify it by adding a piece of hardboard for the sled. It worked, sort of. I still need to make some mods so I can adjust it more precisely. I may end up with something like the Oak Park ones, though I'll probably make my own. Then I wouldn't need the miter channel.
Thanks, guys. Keep the suggestions coming.
30coupe is offline
post #8 of 18 (permalink) Old 01-12-2011, 03:06 AM
Mike Wingate's Avatar
First Name: mike
In a cast iron table, yes. In a wood composite table, no. The mitre groove will weaken the table and may cause it to distort.
Mike Wingate is offline
post #9 of 18 (permalink) Old 01-12-2011, 05:19 PM
I generally agree with this depending on how thick the top is and how well it is braced from the bottom.
I have a phenolic top (3/4" thick) without a miter channel and it is kind of a pain not to have something to easily attach feather boards to.
Tempest is offline
post #10 of 18 (permalink) Old 01-12-2011, 07:31 PM
Cassandra's Avatar
First Name: Cassandra
Hi Russ:
Welcome to the Router Forums!
A miter track is purely optional and a matter of personal choice. Some like the facility of using a miter track. Others (like me) don't have them and do okay without them. One can easily do the same tasks, albeit maybe slightly differently, without the miter track.
Cassandra
Cassandra is offline
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
T-Track vs. Miter Channel Paul3624 Table-mounted Routing 12 05-12-2010 10:25 AM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
Sliding Miter Saw - should I purchase? FinsLeftRight Tools and Woodworking 12 04-12-2009 01:01 PM
